Integra Type R sway bar!!!!
Old Dec 21, 2003 | 03:53 PM
Integras N Civics's Avatar
Default Integra Type R sway bar!!!!
sold
Modified by Integra N Civic at 1:58 AM 1/25/2004
Old Dec 21, 2003 | 08:12 PM
Default Re: Integra Type R sway bar!!!! (Integra N Civic)
Old Jan 1, 2004 | 07:24 PM
Loccster's Avatar
PMed u
Old Jan 1, 2004 | 07:51 PM
ptsiu's Avatar
isn't that sway bar cost only $53.7 from Acura dealer?
Old Jan 1, 2004 | 07:55 PM
irev210's Avatar
Default Re: Integra Type R sway bar!!!! (ptsiu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptsiu &raquo;</TD></TR><TR><TD CLASS="quote">isn't that sway bar cost only $53.7 from Acura dealer?</TD></TR></TABLE>
yup, for a USDM one
a JDM one is more, and if it comes with end links, D brackets and all hardware, then its a pretty decent deal
Old Jan 1, 2004 | 07:56 PM
sUpMaAhChInX's Avatar
is it from 22mm usdm itr or 23mm jdm itr? also does it include bushings, endlinks, bsq kit..etc.?
Old Jan 1, 2004 | 08:02 PM
Default Re: Integra Type R sway bar!!!! (sUpMaAhChInX)
yes whatever you see in the pic TYPE R YA
Old Jan 1, 2004 | 08:05 PM
you didnt answer my question...
Old Jan 1, 2004 | 08:11 PM
Mario's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sUpMaAhChInX &raquo;</TD></TR><TR><TD CLASS="quote">is it from 22mm usdm itr or 23mm jdm itr? also does it include bushings, endlinks, bsq kit..etc.?</TD></TR></TABLE>
Old Jan 1, 2004 | 08:54 PM
DC5ITR329's Avatar
Default Re: Integra Type R sway bar!!!! (Mario)
Actually the US bar and the JDM 96 spec ITR is the same bar. Bump for some good suspension part.
Old Jan 1, 2004 | 09:06 PM
brusso's Avatar
so is it 22 or 23mm....
Old Jan 2, 2004 | 01:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sUpMaAhChInX &raquo;</TD></TR><TR><TD CLASS="quote">is it from 22mm usdm itr or 23mm jdm itr? also does it include bushings, endlinks, bsq kit..etc.?</TD></TR></TABLE> and it comes with whatever you see in the pic
Default Re: Integra Type R sway bar!!!! (brusso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brusso &raquo;</TD></TR><TR><TD CLASS="quote">so is it 22 or 23mm....
</TD></TR></TABLE>usdm
Old Jan 13, 2004 | 03:56 AM
Old Jan 13, 2004 | 07:15 AM
gambo117's Avatar
Here are the Acura parts that will be need:
1.) 52300-ST7-Z01 rear swaybar ($57.30)
2.) 52315-ST7-Z01 swaybar bushing ($3.57) (2 needed)
3.) 52308-SS0-000 bushing bracket ($4.86) (2 needed)
4.) 52316-ST7-Z00 endlink bushing ($1.41) (2 needed)
5.) 52312-ST7-Z00 endlink bushing collar ($3.98) (4 needed) – this part can be reused from the stock swaybar
6.) 90175-ST7-Z00 bolt (8x35) ($1.98) (2 needed)
7.) 94050-08080 flange nut (8mm) ($0.08) (2 needed)
thanks to bret
and his mount kit: http://www.geocities.com/bretq/mounting_kit.html
Old Jan 13, 2004 | 08:07 AM
Default Re: Integra Type R sway bar!!!! (gambo117)
Old Jan 14, 2004 | 05:25 PM
jweezy225
Jun 15, 2006 04:14 PM
egtype-r
Jan 10, 2006 08:24 AM
dc2ali
May 30, 2004 11:25 AM
Bills01ITR445
Jan 28, 2004 03:43 PM
Commodore
May 13, 2003 06:44 PM
