Fluidyne Radiator with Fal Fan
Old Dec 21, 2003 | 03:18 PM
TurboTeG4's Avatar
Default Fluidyne Radiator with Fal Fan
I just got a new fluidyne radiator with the dual fal fans, all the brackets dont come close to fitting the two together. How did you guys fit the dual fans on the full size teg fluidyne radiator. Pics of the custom brackets would be NicE.!
Old Dec 21, 2003 | 03:26 PM
XSSIVE's Avatar
Default Re: Fluidyne Radiator with Fal Fan (TurboTeG4)
bump for you and for some info from others b/c i am thinking of going with a fluidine or koyo and dual fal fans on my teg...
-Mike
Old Dec 21, 2003 | 03:35 PM
TurboTeG4's Avatar
Default Re: Fluidyne Radiator with Fal Fan (XSSIVE)
Looks like I got to cut the Fan where the top hose supposed to go so it can go flush as well as the bottom and where the drain plug is. I think I can make some custom brackets utilizing all the radiator bolt holes.
Whats the bolt hole for on the very bottom of the fluidyne radiator that is sticking out somewhat?
Also is there 2 radiators on the 94 teg cause on my teg there is another radiator in front of the one with the fans on it, I take it this is the one for a/c or maybe had to be put on the get my jdm front end on?
Old Dec 21, 2003 | 03:44 PM
oMek's Avatar
i just got some slim fans from autozone, and use the zp tie things to attach them. works great
Old Dec 21, 2003 | 04:30 PM
threatcon13's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">Looks like I got to cut the Fan where the top hose supposed to go so it can go flush as well as the bottom and where the drain plug is. I think I can make some custom brackets utilizing all the radiator bolt holes.
Also is there 2 radiators on the 94 teg cause on my teg there is another radiator in front of the one with the fans on it, I take it this is the one for a/c or maybe had to be put on the get my jdm front end on?</TD></TR></TABLE> I have the fluidyne radiator w/ fal slim fans on my gsr w/ jdm front end....you have to cut the fan shroud so it will line up w/ the radiator...works fine. that little radiator you are referring to is probably the condensor, there isnt two radiators on tegs, usdm or jdm. Also there is only one model fluidyne for 94-01 integra.
Old Dec 21, 2003 | 04:35 PM
TurboTeG4's Avatar
Default Re: Fluidyne Radiator with Fal Fan (Threatcon13)
So you just used the existing holes on the radiator and made custom brackets or zip ties. Is there clearance for a drag turbo, there better BE
Old Dec 21, 2003 | 04:38 PM
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">So you just used the existing holes on the radiator and made custom brackets or zip ties. Is there clearance for a drag turbo, there better BE </TD></TR></TABLE> no, you dont use custom brackets or zip ties....you use the bracket that came w/ the fal fans. and im sure there will be room for your drag turbo, because I know there will be room for my innovative 60-1.
Old Dec 21, 2003 | 05:30 PM
TurboTeG4's Avatar
Well i mounted the top mount to the fan and position it on my radiator. Im going to need to drill 3 custom holes to fit the top of the radiator. They have one predrilled hole in the bracket by the top water hose but using it causes serious issues to the alignement of the fan and radiator, so im just goin to drill my own holes. But the bottom brackets cant fit so also custom brackets is needed.
Old Dec 21, 2003 | 06:55 PM
96 Ls lnTeG's Avatar
I thought Fluidyne made a Kit to bolt a fal fan to it.. don't quote me on that..
TurboTeG4 How much did you pay for that set-up out of curiousity I was looking into a C&R Radiator
Old Dec 21, 2003 | 11:17 PM
TurboTeG4's Avatar
Default Re: Fluidyne Radiator with Fal Fan (96 Ls lnTeG)
talk to ben at import parts.com he can beat any price you throw at him
Old Dec 21, 2003 | 11:29 PM
Seedc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">talk to ben at import parts.com he can beat any price you throw at him </TD></TR></TABLE>
how much did you pay??
Old Dec 22, 2003 | 12:02 AM
Erik_Pb_Foot's Avatar
New User
Default Re: Fluidyne Radiator with Fal Fan (kendogg)
i ditched the fugly mount mine came with and used door weatherstripping from a chevy astro (i think... has metal to hold it to the door frame... used that to hold the weatherstripping to the fal's "frame") and the zip tie thingies to get it good and tight. no problems as of yet... i'm using 6 zip tie thingies. i made two brackets to bolt the assembly to the jdm radiator support. sorry, i don't have any pictures.
-Erik
Old Dec 22, 2003 | 07:23 AM
rastropovitch
Guest
Posts: n/a
Default Re: Fluidyne Radiator with Fal Fan (Erik_Pb_Foot)
With fluidyne you don't need twin fans by any stretch. a single is good enough
Schu
Old Dec 22, 2003 | 09:46 AM
Muad'Dib's Avatar
Corr Performance Pilot
well.. on my 98 there is a wire that goes to a plug for the smaller fan. I believe that this has to be plugged in cause my AC wont turn on now. so I'll be looking to get a slim fan asap.
accord2civic2prelude
Apr 25, 2010 09:55 PM
95LSS
Jul 24, 2006 06:35 PM
tsmith0819
Mar 29, 2006 09:18 AM
billyhoe
Nov 2, 2004 10:57 PM
