D16Z6 pistons???
Old Dec 21, 2003 | 02:31 PM
hondaboyB18C1's Avatar
Default D16Z6 pistons???
has anyone installed D16A6 non-vtec pistons in a D16Z6 sohc vtec to raise the compression to 10.4 or close to that. Is there proper clearence for the piston-valves???
Old Dec 21, 2003 | 07:02 PM
MrTodd's Avatar
Default Re: D16Z6 pistons??? (hondaboyB16)
There will be plenty of clearance. The compression ratio will be between 9.9:1 - 10.2:1 (depending on which headgasket you use, z6/y8). Not a worthy piston swap IMO.
Old Dec 21, 2003 | 07:16 PM
blackeg's Avatar
Default Re: D16Z6 pistons??? (MrTodd)
check out the pm7 pistons. c/r in the 12's.
Old Dec 22, 2003 | 12:58 AM
5 Skware's Avatar
I missed the boat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrTodd &raquo;</TD></TR><TR><TD CLASS="quote">There will be plenty of clearance. The compression ratio will be between 9.9:1 - 10.2:1 (depending on which headgasket you use, z6/y8). Not a worthy piston swap IMO. </TD></TR></TABLE>
Where did you get those calculations???
I calculated about a 10.5-10.8:1 setup with just swapping in pistons.
p29 pistons still had plenty of piston to valve clearance....and that was &gt; 12:1 CR
Doing the A6 pistons would deffainetly be a worthy swap...still run stock P28 ecu and with a cam and some headwork, will be a very reliable and quick setup on 92 octane
Old Dec 22, 2003 | 12:22 PM
Default Re: D16Z6 pistons??? (5 Skware)
Have you guys actualy did this and ran the engine???
Old Dec 22, 2003 | 01:09 PM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaboyB16 &raquo;</TD></TR><TR><TD CLASS="quote">Have you guys actualy did this and ran the engine???</TD></TR></TABLE>
My D16Z6 with p29 pistons and a head that was milled .020 ran perfect. Pulled that block out after 2 weeks because it was pinging too bad at WOT and I was too poor at the time for management
A6 pistons would be perfect
Old Dec 23, 2003 | 09:30 PM
robtec's Avatar
Default Re: D16Z6 pistons??? (Emerika)
i have them installed in my z6,but before i install them,i flycut them and mill the the dome .060 to take 3.2cc of the dome and get a 11.5cr.
my car runs fine with no pinging whatsoever,how ever if some one do not want to mill the domes,they can drop the cr a litle bit by using a thiker gasket from cometic.
big_daddy234
Sep 21, 2009 09:47 PM
projectef
Jul 24, 2006 03:44 PM
Renegade
Mar 2, 2004 12:36 AM
AztecRacer
Dec 29, 2002 08:07 PM
