wiring up Auto Meter tach on ITR swapped EG, need help please
Old Dec 21, 2003 | 12:42 PM
Girlzcn2's Avatar
Default wiring up Auto Meter tach on ITR swapped EG, need help please
Ok, we're wiring up a Auto Meter tachometer to my Civic hatch with ITR swap. There is a wire on the back of the tach that needs to be wired up to either the ECU or distributor. The problem is, i don't know which wire on the ITR distributor harness i need to patch into to get my RPM signal for the tachometer. Can anyone tell me which wire it is? TIA.
Old Dec 21, 2003 | 01:04 PM
PureBlood's Avatar
Default Re: wiring up Auto Meter tach on ITR swapped EG, need help please (Girlzcn2)
Blue wire from the distributor, its off the connector that only has two wires at the back (closer to firewall) of the distributor
Old Dec 21, 2003 | 01:06 PM
JaeOne3345's Avatar
Default Re: wiring up Auto Meter tach on ITR swapped EG, need help please (PureBlood)
you can also look near the driverside firewall, theres a rubber plug. has a test connection under the plug. the blue wire there is also a tach signal. tap into it. easiest way.
epingquian
Mar 29, 2018 08:29 AM
YumVTEC
Aug 15, 2007 09:26 AM
4dooreg-k
11
Jun 23, 2006 12:50 PM
nonvtec
Apr 5, 2005 11:11 AM
fatboyslim44
May 5, 2004 07:56 PM
