Need some good advice PLEASE!
Old Dec 21, 2003 | 11:34 AM
thehondaguru's Avatar
Default Need some good advice PLEASE!
Satan and ludykrus you guys are my saving grace
Ok I have been working on this h23 vtec motor for a while and put it all together minus the head.
I am debating on sparying on this motor. Not sure yet. My bottom end is Iron sleeved, crank was balanced, and rods shot peened and cyro frozen. I have J.E. 11:1 pistons and total seal rings. Everything is looking good. Head has skunk2 springs+retainers stock valves and crower stage 2 cams.
My question is should I take it back apart and change the rods. I dont want to but could do it later. I just dont want to be disapointed when I want to spray and am scared to break something.
So what do I do? I am so confused! thanks guys
Old Dec 21, 2003 | 01:41 PM
Mikey3000's Avatar
Default Re: Need some good advice PLEASE! (95 lude)
how much shot of nitrous do u want to use? 11:1 is a bit high for nitrous dont you think?
Old Dec 21, 2003 | 02:50 PM
Default Re: Need some good advice PLEASE! (Mikey3000)
either 75 or 100 shot. I dont think 11:1 is too high. Nitrous likes the compression. I am pretty sure the bottom will hold it I am just worried about the rods but really dont want to have to change them if I dont need to. I might not even use nitrous. I am just looking at all the angles. I know myself and I know I will want the extra power at the strip.
Old Dec 21, 2003 | 03:02 PM
LudeyKrus's Avatar
Well, nitrous loves compression to a point. At 11.1:1, I would only go over a 75 shot if you tune it on a wideband. It gets very tight to tune when you spray on high-comp.
What are you going to rev to? I would stay under about 7600, even w/ the balanced bottom end. If you have already put that much money into the motor, I would spare a little more and swap out the rods. It would just make a good precaution.
BUT the only rods for the H23 are the Crower's, and they're nowhere near cheap.
If it were my motor, I wouldn't worry. I would run the oil squirters, aim them right, and dog it out I'm gonna be puttin out similar numbers probably, and I'm using stock, unadulterated rods; yours are cryo'd and shotpeened, which makes them significantly stronger.
Old Dec 21, 2003 | 03:07 PM
Default Re: (LudeyKrus)
Thanks. I am planning on reving to like 75 or 7600. Yeah I know the crowers are it and yes that sucks. I am hoping to get at least 200 to 210 N/A. So I might not even want to use N20. Also If I do do it I would have to do direct port so I dont F%$^ up #1 piston.
I just dont want to pull it all apart again.
By the way, where are you in GA. I am based in Valdosta but am deployed to places unknown right at the moment.
Old Dec 21, 2003 | 06:08 PM
LudeyKrus's Avatar
I live in Flowery Branch/Oakwood, but I am frequently around Gainesville and Buford/Lawrenceville, and I work at the mall.
If you're ever in the area, you should stop by and check out my motor
Old Dec 22, 2003 | 10:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">I live in Flowery Branch/Oakwood, but I am frequently around Gainesville and Buford/Lawrenceville, and I work at the mall.
If you're ever in the area, you should stop by and check out my motor</TD></TR></TABLE>
Well thanks for the help. I will probebly just leave it alone and only spray like a 65 shot tuned on a wide band. So, where do you get your stuff tuned. I havnt had to do anything like that since I have been in GA. So I have no clue where to go.
Old Dec 22, 2003 | 10:34 AM
LudeyKrus's Avatar
I haven't had anything tuned yet, but the bigger shops around here are Balanced Performance, Knowledge Performance, and one or two more.
I know they do a pretty good job, but they're are fairly expensive from what I hear.
Old Dec 22, 2003 | 12:50 PM
OK thanks again. I will try to look them up. There isnt crap for places around Valdumpster worth trusting
rudyndrew
Feb 8, 2011 12:40 PM
shazbot
40
Oct 5, 2004 10:15 AM
viprcr1
Jan 27, 2004 11:29 AM
thehondaguru
Dec 22, 2003 02:32 PM
typeSwarrior
Feb 3, 2002 09:49 PM
