JDM gauge clusters - Difference between 96 Spec & 98 Spec
Old Dec 21, 2003 | 08:12 AM
SubTitle's Avatar
Default OT- JDM Cluster
how could u tell the diff. between a 96-97 spec and a 98+ JDM ITR CLuster
Old Dec 21, 2003 | 08:18 AM
MiraiZ's Avatar
Default Re: OT- JDM Cluster (SubTitle)
The location of some of the lights (seat belt..brakes) are diffrent...and the circuitry is different
Old Dec 21, 2003 | 08:20 AM
SubTitle's Avatar
Default Re: OT- JDM Cluster (MiraiZ)
Im asking because im going to check out a Cluster and i heard the 96-97 Spec ones wont plug and play on 98+ tegs, i would need a 98+ cluster right?
Old Dec 21, 2003 | 08:22 AM
MiraiZ's Avatar
it will...just swap the circuit film on the back
Old Dec 21, 2003 | 08:27 AM
SubTitle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">it will...just swap the circuit film on the back</TD></TR></TABLE>
IM going to let my buddy use my cluster , so i need a plug and play one
Old Dec 21, 2003 | 09:03 AM
MiraiZ's Avatar
the water temp gauge and fuel gauge won't work then...
Old Dec 21, 2003 | 09:40 AM
SubTitle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">the water temp gauge and fuel gauge won't work then...</TD></TR></TABLE>
ok then thanx man
WANTED 98+ JDM ITR CLUSTER
Old Dec 21, 2003 | 10:05 AM
cxSHOE's Avatar
well its not that it wont work, youll have to rewire it to anothe location...(wire on gauge side will connect to a different wire on car side) i just wired my 99 jdm type r gauge in my 93 hatch... no problems and all gauges work?? so im pretty sure if you folow the leads in the back of the gauge you can find out what wire it will hood up to...but if your just letting your bro borrow it... then who cares if little things dont work right??
Old Dec 21, 2003 | 03:17 PM
SubTitle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">The location of some of the lights (seat belt..brakes) are diffrent...and the circuitry is different</TD></TR></TABLE>
anyone have good pics (like close ups) and details of the diff. on the 2 clusters
Old Dec 21, 2003 | 03:48 PM
esponet's Avatar
96-97 has a overheating cat warning light, (it looks like a smoking chevy emblem) 98+ does not...
Old Dec 21, 2003 | 03:52 PM
SubTitle's Avatar
Default Re: (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">96-97 has a overheating cat warning light, (it looks like a smoking chevy emblem) 98+ does not...</TD></TR></TABLE>
hmm. any pics of that? also someone sent a a pic of a JDM ITR cluster which had the ABS light symbol, does that mean its a 98 and up one, or did the 96-97 ones have it also
heres the pic
Old Dec 21, 2003 | 05:07 PM
fuck honda-tech's Avatar
Default Re: (SubTitle)
mine has abs symbol!
Old Dec 21, 2003 | 05:57 PM
SubTitle's Avatar
help?
Old Dec 21, 2003 | 06:05 PM
Saga's Avatar
Having the abs light means nothing.
If you can provide a picture of the back of the cluster, I can help.
Old Dec 21, 2003 | 10:20 PM
DB8ITR's Avatar
That looks like a 96 spec cluster ... the 95.5 - 97 did have abs and the overheating cat warning light is right above the H in the temp gauge.
Old Dec 21, 2003 | 10:34 PM
SubTitle's Avatar
Default Re: (R #189)
hmmm....anyone have pics of the 2 clusters to compare
cxSHOE's Avatar
not sure if this helps but heres a jdm 97 itr with the cat heat sensor in the gauge..
http://cgi.ebay.com/ebaymotors...=6763
Old Dec 22, 2003 | 08:33 AM
Jon D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SubTitle &raquo;</TD></TR><TR><TD CLASS="quote">hmmm....anyone have pics of the 2 clusters to compare</TD></TR></TABLE>
I do but i am dont know how to post pics!!
Old Dec 22, 2003 | 03:29 PM
B17AGSR's Avatar
Default Re: (jh4dc23spoon)
If you switch the circuits out, make sure you unscrew 3 or 4 screws in the back holding the carbon fiber bezel also. Its not just held on by the clips. I broke mine cause I didn't know.
Old Dec 22, 2003 | 04:12 PM
SubTitle's Avatar
Default Re: (B17AGSR)
does having the SRS Symbol mean its a 98?
Old Dec 22, 2003 | 08:41 PM
MiraiZ's Avatar
there should be a serial number on it somewhere...that will tell you the year
Old Dec 22, 2003 | 09:34 PM
SubTitle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SubTitle &raquo;</TD></TR><TR><TD CLASS="quote">does having the SRS Symbol mean its a 98?</TD></TR></TABLE>
Old Dec 22, 2003 | 10:11 PM
skafia's Avatar
25 Year Member
ABS or SRS does not determine the years of the vehicles, they could have added that as an option.
The positioning of the symbols is what determines if its 97 or 98+.
Just get a picture of a 98+ USDM integra cluster and the positioning of the icons should be the same, if it's different, then it's a 97 or older.
Old Dec 23, 2003 | 06:18 AM
SubTitle's Avatar
Default Re: (skafia)
oh ok
Old Dec 23, 2003 | 05:50 PM
SubTitle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh4dc23spoon &raquo;</TD></TR><TR><TD CLASS="quote">
I do but i am dont know how to post pics!!</TD></TR></TABLE>
Email the to me, ill post em, u got PM
