obd-1 Wiring Whoes *help* ? blownhatch ?
Old Dec 20, 2003 | 09:39 PM
turbo sol's Avatar
Default obd-1 Wiring Whoes *help* ? blownhatch ?
I have an obd-1 d16z6 in my 89 crx si using blownhatch's conversion harness. I had some tach problems and have isolated the proble to my distributor, which i have replaced and still does not work. So after more trouble shooting i have come up with the following.
1. my "white" wire as denoted for the 89 si, the one that attaches to the firewall side of the igniter does not have continuity with the body ground as it should. I see in the schematics this wire goes directly to the ECU. —WHAT PIN DOES IT GO TO ON A P28 ECU?—
2. my blue wire does not have continuity with the body ground either. The schematic shows this going to the tach. —can i run a wire straight to the tach and solve this problem?—
I have been getting no where on this problem and need my car to run soon. please help if you have any input. thanks guys.
Old Dec 20, 2003 | 09:41 PM
turbo sol's Avatar
Default Re: obd-1 Wiring Whoes *help* ? blownhatch ? (turbo sol)
the wire labeled white in this image is the one i was refering to in the first post.
Old Dec 21, 2003 | 05:12 AM
turbo sol's Avatar
to the top.
Old Dec 21, 2003 | 08:49 AM
crx_91si's Avatar
wire color
white
PIN #
B12
Function
CYP Sensor Signal
i think this is correct
if you need more help, try this
http://www.hondaswap.com/articles/viewer.php?id=17
Old Dec 21, 2003 | 10:30 AM
turbo sol's Avatar
Default Re: (crx_91si)
is the b12 pin for a P28 or pm6?
Old Dec 21, 2003 | 10:50 AM
turbo sol's Avatar
Default Re: (turbo sol)
i see that it is for the p28 does anyone have a chart like that for a pm6?
Old Dec 21, 2003 | 02:04 PM
crx_91si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo sol &raquo;</TD></TR><TR><TD CLASS="quote">i see that it is for the p28 does anyone have a chart like that for a pm6?</TD></TR></TABLE>
here ya go, this should help find what your looking for
http://b16a.honda-perf.org/wiringb16.htm
good luck
mike
Old Dec 22, 2003 | 08:57 AM
turbo sol's Avatar
maybe i am making this more confusing that it is worth. but as i look over the pinouts nothing jumps out as definitive.
http://www.mobstyle.com/crx/ecu_pinouts2.asp has the following listed
pm6 B15 & B17 &gt; ignition ouptut signal (to ignitor unit in distributor) connected to harness later) &gt;&gt; white wire
pm6 C16 &gt; crank sensor (in distributor) &gt;&gt; white wire
from a post from USDM 4G VTEC I found
pm6 /89 si ecu/
B15 &gt; ignition control module
B17 &gt; ignition control module
p28 /92-95 d16z6 ECU/
B12 &gt; white wire &gt; CYP Sensor Signal
so do i just take the "white wire" from my ignitor and run a straight line to my ECU @ B12 to take it out of the equation? Why did the 89 ECU have to pins for it and now i can only find one?
Old Dec 22, 2003 | 10:26 AM
turbo sol's Avatar
a distributor has a Top Dead Center (TDC) sensor, Crank (CKP) Sensor, and Cylinder Position (CYP) Sensor.
in the schematic for a 89 si distributor (thats all I have) it shows the TDC and CKP sensors are in the black shaped california looking thing on the distributor.
Does the CYP sensor infact run throught the ignitor straight back to the ECU?
I have checked my ECU in another car and it started that car jsut fine, so somehting is up with my wiring/dist/ignitor.
Old Dec 22, 2003 | 11:50 AM
JOEY F.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo sol &raquo;</TD></TR><TR><TD CLASS="quote">in the schematic for a 89 si distributor (thats all I have)</TD></TR></TABLE>
I think that might be your problemo...I dont think you can use the OBD0 dizzy with the OBD1 ECU. You have to source a 92-95 si/ex dizzy.
Old Dec 22, 2003 | 01:13 PM
turbo sol's Avatar
Default Re: (JOEY F.)
I have found the gold i was looking for.
all for a 92-95 ecu and dist.
CKP &gt;
B15 - blu/grn
B17 - blu/yel
TDC &gt;
B13 - orn/blu
B14 - wht/blu
CYP &gt;
B11 - orn
B12 - wht
there was a nice little chart in the emmision control / trouble shooting area of the chiltons i had section 4-111
710times
Apr 18, 2017 11:38 AM
1ceman
May 26, 2015 04:16 AM
1ceman
May 19, 2015 02:37 PM
carlosd68
Dec 21, 2006 02:06 PM
Girlzcn2
Dec 22, 2003 04:34 AM
