Engine Cooling Question
Old Dec 20, 2003 | 09:05 PM
TurboGSR00's Avatar
Default Engine Cooling Question
My radiator hoses get so tight that there is no play in it at all. We changed the water pump out and put diff thermastat in and still blows up like a baloon. Air is getting in the system some how. Has anyone else had this problem ? Anything is helpful
Old Dec 20, 2003 | 09:10 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Engine Cooling Question (TurboGSR00)
did u try bleeding the air out of the system? and changing the hoses.....also u could have a leaky headgasket and the coolent track is getting some compression..
Old Dec 24, 2003 | 02:50 AM
1.8turbolsvtec's Avatar
the car is turbo yes .when you pushed it under boost if the coolant over flow fills up over the max and the temp only goes up when you are pushing than it is a head gasket. " BORDER="0">
Old Dec 24, 2003 | 02:51 AM
OItani
Aug 20, 2012 06:01 AM
DK-EK9
Feb 14, 2012 09:20 PM
LstCivic
Sep 6, 2010 09:15 AM
rlnhrd8
Feb 15, 2009 10:05 PM
Kaan
Nov 28, 2005 07:19 PM
