Tranny Prblems
Old Dec 20, 2003 | 02:07 PM
Dohcvtec59's Avatar
Default Tranny Prblems
95 Civic Coupe, B16a2 swap!!!
Ok I have an ACT 6-puck clutch with heavy duty pressure plate. I slamed harshly in second and now have a knocking noise in my tranny....Here are examples of my syptoms: Knocking noise in all gears Except reverse, Only when I'm on the accelerator. Also When I'm off the accelerator comes a low grinding noise, All these problems happen only when in gear......Need help to troubleshoot
Old Dec 20, 2003 | 02:23 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: Tranny Prblems (Dohcvtec59)
OT: Didn't know you needed a clutch/pressure plate like that for a B16a2...unless it's modded up the ****.
Old Dec 20, 2003 | 02:52 PM
boostedcivicsir's Avatar
Mr. Badwrench
drain the fluid. look for metal. with that clutch, chances are, you dammaged the diff. why did you go with such a radical clutch?
Old Dec 20, 2003 | 03:47 PM
Dohcvtec59's Avatar
Default Re: Tranny Prblems (R_EG)
Actually its not really modded that much but umm.... all i have is a stock bottom end every thing else is beefed up!!!!
Old Dec 20, 2003 | 03:49 PM
Dohcvtec59's Avatar
Default Re: Tranny Prblems (boostedcivicsir)
When i changed everything on the motor I was told too by a bunch of people so i did.. i think i need to down size it a tad bit any suggestions? So you think I toasted the tranny....?@#$?????? I was thinking the exedy single disc with heavy pressure plate... That would really suck about my tranny.......thanks for the tip.... I actually never thought to do that!!!
hitvtecgetloud09
Oct 6, 2007 09:35 PM
Junkyard2000
11
Dec 20, 2005 11:51 AM
Stoich EG2
Mar 26, 2005 06:07 AM
snatch
May 1, 2004 05:45 PM
AEM R&D
Mar 10, 2003 04:22 PM
