i need to take out my tranny fill plug, is it a 3/8 drive?
i'm gonna change my tranny fluid today, but i just wanted to know is the fill plug any different (or in a different location) from the the usdm d series trannys? does the fill plug use the 3/8 in drive from a socket, or is it something else? this is on a jdm s1 cable tranny by the way
Make sure you take out your fill plug first, it'll save you alot of problems if you find out that you can't take it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryanstev »</TD></TR><TR><TD CLASS="quote">Make sure you take out your fill plug first, it'll save you alot of problems if you find out that you can't take it out.</TD></TR></TABLE>
Very good advice. I almost didnt get mine out after I stripped the hell out of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">fill plug is a 17mm bolt, drain plug is a 3/8th drive</TD></TR></TABLE>
VtecAdvantage
Mar 30, 2010 10:10 PM
grante
May 2, 2004 05:36 PM
SimbaDogg
Dec 20, 2003 01:20 PM
