momo steering wheel install dilemna! help
Old Dec 20, 2003 | 11:43 AM
igo4bmx's Avatar
Default momo steering wheel install dilemna! help
i got my OEM steering wheel off and the airbag, but there is an SRS reel that houses a ribbon for the horn and such, which i cannot get off
a wire harness is in the front and back and both cannot be removed!
help
Old Dec 20, 2003 | 12:01 PM
TeamNextGenChris's Avatar
Default Re: momo steering wheel install dilemna! help (igo4bmx)
if you follow the cable reel harness back about 6" down the steering column there's a connector.unhook that and take out the 3 or 4 screws that secure it and it'll come
right off.
chris
Old Dec 20, 2003 | 01:03 PM
igo4bmx's Avatar
Default Re: momo steering wheel install dilemna! help (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">if you follow the cable reel harness back about 6" down the steering column there's a connector.unhook that and take out the 3 or 4 screws that secure it and it'll come
right off.
chris</TD></TR></TABLE>
thanks alot for that info!
i finally got it done!
Old Dec 20, 2003 | 02:00 PM
King Tut33's Avatar
Yep, welcome to the new world of no airbag, horn, and cruise control .
Old Dec 20, 2003 | 02:04 PM
igo4bmx's Avatar
Default Re: momo steering wheel install dilemna! help (King Tut33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 &raquo;</TD></TR><TR><TD CLASS="quote">Yep, welcome to the new world of no airbag, horn, and cruise control .</TD></TR></TABLE>
hahaha
i never ever ever use cruise control
i never horn ( i just throw things at people)
and no airbag...
i guess i'll tape a pillow to the MOMO
SNAP off system will be in shortlywhenever exospeed gets them in
Old Dec 20, 2003 | 02:10 PM
MaxSterling's Avatar
your horn don't work b/c you need to bypass the horn relay after removal of cruise control. my non-srs wheel horn works perfect after this mod
Old Dec 20, 2003 | 03:31 PM
igo4bmx's Avatar
Default Re: momo steering wheel install dilemna! help (MaxSterling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxSterling &raquo;</TD></TR><TR><TD CLASS="quote">your horn don't work b/c you need to bypass the horn relay after removal of cruise control. my non-srs wheel horn works perfect after this mod</TD></TR></TABLE>
i'll be going with quick very shortly so the wheel's horn bumper will never work
Old Dec 20, 2003 | 04:29 PM
kingSfit's Avatar
just cut them off duh!
Old Dec 20, 2003 | 04:31 PM
EK MONEY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">
hahaha
and no airbag...
SNAP off system will be in shortlywhenever exospeed gets them in </TD></TR></TABLE>
LMAO
Old Dec 20, 2003 | 04:38 PM
i'll be going with quick very shortly so the wheel's horn bumper will never work</TD></TR></TABLE>
it isn't hard at all to make the horn usable.i have the Tekniq quick realease that has contacts that pass through the detachable hub,so you can still use the steering wheel buttons....you could also mount a button anywhere on the dash for the horn.....remember where you unplugged the cable reel?on the car side of that plug,one of those wires(sorry,been a while so i can't remember which one)is the ground for the horn.find it and extend it to a switch(whether it be your horn button or a button mounted elsewhere).hook it to one pole of the switch and ground the other side of the switch.when you hit the button and complete the circuit,it grounds the horn circuit and it blows-simple as that....BTW-my car is an EX that had cruise,and this is all i did to make the horn work-no bypassing relays or anything of that nature.
chris
kPRO dz
May 11, 2009 02:30 PM
5hifty_ES1
Honda Civic (2001 - 2005)
Jul 5, 2007 07:29 AM
dt4life
Apr 8, 2006 02:42 AM
ch00dlz
Jan 3, 2006 07:37 PM
GReddyB18C
Aug 17, 2002 01:06 PM
