Problem: Blowing fuses
Old Dec 20, 2003 | 09:55 AM
rizen's Avatar
Default fuse problem???
Last night at the track, I shifted into second gear. After shifting into second gear my instrument gauge went out...
I went and looked at the instrument fuse and it was blown, so I put a replacement fuse in there. After I did that, it sparked upon putting it in. At that point my tails were out as well as my turn signals (running lamps?) so this morning I checked under the hood and that fuse was blown too. I replaced it with the correct fuse as well and the tails were working again. So then I changed the instrument one again and now they'r both blown again.
Any input guys???
Old Dec 20, 2003 | 09:19 PM
dk127's Avatar
Yikes, sounds like something is exposed and touching... Check by the fuse box I guess, check the wiring around the area, make sure the two aren't touching each other. Otherwise, you just have to find where the short is.
Old Dec 20, 2003 | 10:35 PM
Bbasso's Avatar
Default Re: fuse problem??? (r1zen)
What ever you do DO NOT PUT A bigger fuse in the place, you could cause a lot of damage to your wiring harness.
Old Dec 20, 2003 | 11:31 PM
92TypeR's Avatar
FSAE
Default Re: fuse problem??? (Bbasso)
Damn, out of all the electrical/mechanical problems, locating a short is the hardest, and even worse when it starts blowing your ECU fuse.
Check exposed ground points also.
Old Dec 21, 2003 | 08:13 AM
ZygSpeed's Avatar
Default Re: fuse problem??? (92TypeR)
This may sound like a bit of a long shot ... but I may have heard of something similar when one or more of the primary O2 sensor wires get shorted.
Which might make sense after a hard shift ... ?
Check underneath there by the sensor and see if it looks like movement of the exhaust/sensor got clost to a heat shiels and got crimped/broken or rubbed through.
Old Dec 21, 2003 | 08:16 AM
type-r 01 886's Avatar
Default Re: fuse problem??? (zygspeed)
It turned out being a couple wires that were astray from his stereo. When he shifted... both wires touched a metal place; hence, shorting the circuit. He fixed the problem with a little wire alchemy
Old Dec 21, 2003 | 09:48 AM
dk127's Avatar
Default Re: fuse problem??? (type-r 01 886)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-r 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">It turned out being a couple wires that were astray from his stereo. When he shifted... both wires touched a metal place; hence, shorting the circuit. He fixed the problem with a little wire alchemy
Well, I was right about the 2 wires touching!
So I assume its an aftermarket stereo?
allenlavoie
Apr 23, 2012 03:34 AM
Br1gHtDc2
Sep 26, 2008 07:43 AM
Sic_DA_Nine
Jan 8, 2007 09:54 AM
illusion
May 29, 2003 11:07 AM
