Setting the timing without removing the pulley
Old Dec 20, 2003 | 09:42 AM
boostedcvc's Avatar
Default Setting the timing without removing the pulley
If the timing is off a few degrees and i need to reset the timing, can i line the crank pulley white mark up with the pointer on the plastic cover or do i have to take the crank pulley off and align the timing marks on the timing belt pulley with the mark on the block.
Old Dec 20, 2003 | 11:25 AM
Mikey3000's Avatar
Default Re: Setting the timing without removing the pulley (boostedcvc)
just align the mark on the pulley with the pointer.
Old Dec 22, 2003 | 06:36 AM
vtecb20coupe's Avatar
B A N N E D
no need to take the pulley off. just align the mark on the pulley to the cover and be sure the gears are aligned as well.
Old Dec 22, 2003 | 10:24 AM
IN VTEC's Avatar
I've found the pullley and timing belt cover marks to be dead on. The only error you'll find is in how much care you take in lining up the marks and your POV.
DavidCRV
Aug 26, 2013 03:12 PM
suje
14
Feb 22, 2012 04:19 PM
94dxt
Oct 27, 2004 12:36 PM
