Another hard question for the Honda tech gods.
Old Dec 20, 2003 | 07:05 AM
slp mode's Avatar
Default Another hard question for the Honda tech gods.
Among the jumping idle I have, Nobody seems to know what causes the clunking sound in the front end while driving. I am thinking that it could be my bad axles, My boots are worn so I'm thinking maybe it has something to do with the bearings inside being bad, but it only started it when I put my neuspeed sport springs on.
any thoughts?
matt
Old Dec 20, 2003 | 07:14 AM
jc836's Avatar
Default Re: Another hard question for the Honda tech gods. (slp mode)
Having no idea what your mileage is, I can only say that MY Neuspeed Sport/Koni "yellow" shock setup does not have any problems after 30,000 miles including track days. You say that you know that the CV joints are an issue-take care of that and see what happens. I suspect that the lowering simply agravated the existing problem rather than causing it. WHy you have an idle problem is an unknown since you tell us nothing about whether you have any engine mods, the mileage on the car and very important how you are driving it. Could be something as simple as a new cap, rotor, wires and plugs and set the timing and valves.
Good luck and happy holidays
Old Dec 20, 2003 | 08:58 AM
specalk's Avatar
ive got the same problem,
https://honda-tech.com/zerothread?id=710805
Old Dec 20, 2003 | 09:28 AM
92LudeSI's Avatar
For your clunking problem. I might have an idea. I have ground controls on stock shocks/struts and the spring gets stuck up in the top of the strut in that rubber gasket type thing and when the wheel goes down the spring sticks on the top and then clunks when the wheel comes back up becuase the spring hits the bottem of the coilover. Im not sure if that would be the problem in your case having springs but jsut thought id let you know.
Old Dec 20, 2003 | 11:19 AM
ExodusFX's Avatar
Have you checked for worn bushings?
Old Dec 20, 2003 | 11:48 AM
slp mode's Avatar
Default Re: Another hard question for the Honda tech gods. (jc836)
the car has ruffly 140,000. I agree that maybe the springs aggrivated a existing issue. as far as my idle problem, I posted a previous thread about that, exodus helped me out on that one.thnks bro,
and as far as my bushings they all look fairly decent, no rotting or anything, maybe they were replaced before I got the car.
It is a light clunking, that I feel more than I hear, and it's very very inconsistent.
Old Dec 26, 2003 | 11:50 PM
95ONE's Avatar
old shocks? Barely bottoming out?
BobJoe67
Classic Hondas
Sep 1, 2013 01:42 PM
dlncooke
Engine Management and Tuning
Mar 27, 2013 11:32 PM
eagerkc
Aug 28, 2010 04:25 PM
toofatt
Mar 26, 2009 06:26 PM
NightHawk
16
Apr 16, 2003 05:52 PM
