Having Problem fitting GE Dowel Pins
Old Dec 20, 2003 | 12:11 AM
MugenB16A2's Avatar
Default Having Problem fitting GE Dowel Pins
Hello,
I just received my Golden Eagle LS/VTEC Dowel Pins, and I noticed that they fit perfectly in both ends of the head and block, HOWEVER, they do NOT pass through the Head gasket... What is wrong???
Old Dec 20, 2003 | 12:16 AM
badCRX's Avatar
New User
Default Re: Having Problem fitting GE Dowel Pins (MugenB16A2)
Do your stock ones fit through?
Old Dec 20, 2003 | 12:29 AM
MugenB16A2's Avatar
Default Re: Having Problem fitting GE Dowel Pins (badCRX)
no, the Golden Eagle Dowel pins are so , u don't have to drill out your head, they are chamfered. Here's the Link so u can understand what I am talking about.
http://www.tornactive.com/pd_golden_eagle_full.cfm
Old Dec 20, 2003 | 05:17 AM
onetwothree's Avatar
Are you putting the dowel in first then the headgasket? Maybe you have to put the headgasket on first then the dowel then the head. hth
Old Dec 20, 2003 | 11:42 AM
badCRX's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenB16A2 &raquo;</TD></TR><TR><TD CLASS="quote">no, the Golden Eagle Dowel pins are so , u don't have to drill out your head, they are chamfered. Here's the Link so u can understand what I am talking about.
http://www.tornactive.com/pd_golden_eagle_full.cfm</TD></TR></TABLE>
Either end of those dowel pins should fit through the hole, because on one side of the dowel is the perfect fit for the head gasket and the other side of the dowl should be smaller to fit the smaller hole in the head.
Old Dec 20, 2003 | 11:47 AM
MugenB16A2's Avatar
it's not working
HELP!!!
Old Dec 20, 2003 | 12:06 PM
thad
Guest
Posts: n/a
what head gasket are you using? if the pins fit the block and the head properly then the problem its the gasket, bore it a little.
Old Dec 20, 2003 | 12:10 PM
MugenB16A2's Avatar
Default Re: Having Problem fitting GE Dowel Pins (thad)
I'm using an LS gasket, I'm an idiot, I put the small end in the block, and it was in the wrong place.... DUH!!! this is all around 2 am after about 6 beers, and a strike out with a girl I was with all night !!! LMAO... so my brain was out of order at the time.
Thanks for the Help people.
Old Dec 20, 2003 | 07:10 PM
mtber's Avatar
Shoulda called me buddy, I coulda slapped you around and called you silly.
Old Dec 20, 2003 | 07:42 PM
MugenB16A2's Avatar
Default Re: (mtber)
Well Call me Sally!!!!!!!
Old Dec 23, 2003 | 03:56 PM
MugenB16A2's Avatar
Default Re: (MugenB16A2)
New Problem...
they do NOT FIT inside the Head???
Has anyon used these before????
I need answers ASAP I this is keeping me from finishing the build.
Old Dec 23, 2003 | 04:13 PM
granada_sun's Avatar
Please say this isn't after 6 beers....
nah a buddy of mine had the same problem, they were very tight going into the b16 head AND the LS block. He just took a rubber mallot and started them into the block, put the head gasket on, then lowered the head onto the dowels.
The weight of the head pretty much sat itself on them, then tightened the head bolts in order. 8k later and no leaks.
Old Dec 23, 2003 | 04:58 PM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenB16A2 &raquo;</TD></TR><TR><TD CLASS="quote">they fit perfectly in both ends of the head and block</TD></TR></TABLE>
Here they did.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenB16A2 &raquo;</TD></TR><TR><TD CLASS="quote">they do NOT FIT inside the Head???</TD></TR></TABLE>
........and now they don't???
Old Dec 23, 2003 | 05:45 PM
-KangaRod-'s Avatar
do you still need to plug the oiling hole in the head?
Old Dec 23, 2003 | 08:44 PM
MugenB16A2's Avatar
Default Re: (granada_sun)
i actually had to hone out the gasket in order to make them fit.
Old Dec 23, 2003 | 08:55 PM
Default Re: (-KangaRod-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- &raquo;</TD></TR><TR><TD CLASS="quote">do you still need to plug the oiling hole in the head?</TD></TR></TABLE>
yes, the head has to be either threaded and plugged on welded to block the oil for the remote line on the back of the block.
Old Dec 24, 2003 | 06:30 AM
vtecb20coupe's Avatar
B A N N E D
yea, i've heard it's a really tight fit for the head gasket but fits the head and block perfect.
Old Jan 5, 2004 | 12:00 PM
X-Mazda 3 Racer's Avatar
Default Re: (vtecb20coupe)
Sorry for the confusion, we will have more detailed instructions on how to get them to fit soon. If you are using one of our gaskets then both sides are opened up to accept the dowels without any modification, but if you are using a completely stock gasket, then some minor sanding of the gasket in the dowel hole location may be neccesary. It's prett easy though. If you have any more questions, please let us know. Thanks
AllMotor12s
Apr 17, 2005 05:56 AM
evilone
Dec 21, 2004 03:34 PM
na200whp
17
Aug 14, 2004 06:50 PM
PupaScoopa
Jul 25, 2004 10:50 PM
servion
Jul 7, 2003 01:15 PM
