Gas commin outta everywhere....help!!!
Old Dec 20, 2003 | 12:09 AM
I Want An Si's Avatar
Default Gas commin outta everywhere....help!!!
Tonight im driving along and my car shuts off....try to restart but it will crank for like half of a turn then stop... i get out and check under the hood....gas is comming outa the intake....white smoke outta the tailpipe...get it home and get the plugs out....theres gas flooded in all the cylinders...anyone got any ideas? ive never heard of anything like this..
Old Dec 20, 2003 | 05:19 AM
litlekikr's Avatar
Default Re: Gas commin outta everywhere....help!!! (I Want An Si)
check the seals on the injectors, possibly they cracked and are dumping fuel into the manifold? or your injectors are stuck wide open.
Old Dec 20, 2003 | 07:37 AM
well i took out the plugs....disconnected the dizzy and cranked it over to shoot all the fuel out.... a lot of fuel was in there!!!... i reset the ecu and then put everything back together and everything "seems" fine now....im thinking maybe its the ecu? fock this is so weird...im afraid its going to happen again....
Old Dec 20, 2003 | 09:58 AM
Teknic73's Avatar
my guess would have been the seals on the injectors, hopefully your job did it!
Old Dec 21, 2003 | 04:41 PM
Anyone else...i have a hard time believing injector seals...since the gas wasnt commin out nowhere near the fuel rail...
Old Dec 22, 2003 | 09:10 AM
abcdefg
Old Dec 27, 2003 | 05:34 PM
nikitad's Avatar
some sensor went bad and is causing it to run rich?
well.... rich in this case is a big stretch.
Old Dec 27, 2003 | 07:51 PM
Riceburner247's Avatar
Default Re: Gas commin outta everywhere....help!!! (nikitad)
I feel stupid. I just posted almost the same thing 2 minutes ago.
White smoke means that coolant is leaking into the combustion chamber. You might want to look at the color of your oil too.
Dylan29
Jun 17, 2018 10:01 PM
sevenfc
Jul 12, 2009 11:56 PM
bitz95civ
Dec 30, 2005 02:38 PM
kur0ryu
May 2, 2004 07:28 AM
CRX Si
Mar 11, 2003 03:50 PM
