B18A Header fit the B18B??
Old Dec 19, 2003 | 09:46 PM
superboy's Avatar
Default B18A Header fit the B18B??
Would a B18A header fit the B18B?
are they the exact same length?
thanks in advance.
Old Dec 19, 2003 | 10:06 PM
riceball777's Avatar
Default Re: B18A Header fit the B18B?? (superboy)
all b series headers bolt up to all bseries blocks
the only difference is that the length of the headers are different for many cars
even if the header is too long or too short it can easily be made to work
Old Dec 20, 2003 | 12:59 AM
B16OnTop's Avatar
Default Re: B18A Header fit the B18B?? (riceball777)
yes, its long enough where it'll clear your oilpan/block
Old Dec 20, 2003 | 07:03 AM
insane_integra's Avatar
Default Re: B18A Header fit the B18B?? (B16OnTop)
i got a exhuast manifold off a b16....and i am putting it on my b18a.....the differnce on the two exhuast manifolds is the downpipes.....b16 exhuast manifold goes 2 into 1......91 b18a exhuast manifold only has 1....b16 exhuast manifold is shorter too.......
Old Dec 20, 2003 | 07:16 AM
evil b's Avatar
actully..the header doesn't bolt up to the block, it bolts up to the head easily confused..but if you want to get tech, it does bolt up to the block to hold the downpipe up
Old Dec 20, 2003 | 07:23 AM
91tegrals's Avatar
thanks for the tech segment there bud i think we all knew that but anywayz yes it will bolt up but i think the 02 sensors are in diff places...
Old Dec 20, 2003 | 09:54 AM
b00sted4dr's Avatar
Default Re: (whiteteg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteteg95 &raquo;</TD></TR><TR><TD CLASS="quote">actully..the header doesn't bolt up to the block, it bolts up to the head easily confused..but if you want to get tech, it does bolt up to the block to hold the downpipe up </TD></TR></TABLE>
haha, and hes only 16 .
Old Dec 23, 2003 | 01:22 PM
91tegrals's Avatar
gotta love a genius
Old Dec 23, 2003 | 02:10 PM
B16OnTop's Avatar
if you were reffering to my post, i knew that, i was talking about the length of the header, the header being long enough to clear the block thats why if you have an LSVTEC with a pr3 head they still reccomend going with the header for the p75 head because it clears the block better then the header for the pr3 head
R.A.T.
Dec 18, 2007 08:24 AM
zensoku207
Apr 9, 2004 11:59 AM
Jmunk
Sep 27, 2003 09:15 AM
See Are X
Aug 16, 2002 05:40 PM
The Rob
Apr 15, 2002 08:33 AM
