mini-me in 91 hatch need rpm activated pill where to buy it at?
I have in my car a d16a6 bottom end with a 98 y8 head and a pm6 ecu i was wonderign where to buy an rpm activated pill for my car and where exactly does the pill go. Dont have the cash to buy a vafc and dont want to put vtec on flip switch.
So I take it that you don't have the RPM switch yet either? I would get this from Summit:
Summit RPM Activated Switch
It's got adjustable RPM points, makes the perfect ghetto VTEC controller/actuator. You'll also need a 12V auto relay from Radio Shack which is only about $5. It will convert the negative 12V output from the RPM switch to a 12V+ output to activate the VTEC solenoid.
Thanks for the help. And all it will control is vtec correct wont mess with anything else? Have been reading tons about mini-me but just want to make sure before i order it or install it. Thanks again for the help.
I don't have the actual msd rpm pills for sale (uless i have a random one around here you may need, i'll throw it in) but i do have 2 msd rpm activated switches for sale if you need one, both set up for 4cyl cars...the pills you can get from summit for around $20. Here is my FS post https://honda-tech.com/zerothread?id=706173 let me know if you need one.
-Mike
-Mike
blkhatch92
Nov 29, 2005 11:04 AM
kenjief8
Dec 27, 2004 06:58 AM
CimorelliCRX
Jul 29, 2002 11:12 AM
CLICC916
Sep 20, 2001 11:06 PM
