What to do with installing a IAC valve
Old Dec 19, 2003 | 05:55 PM
specalk's Avatar
Default What to do with installing a IAC valve
what needs to be done when installing the IAC valve ( Idle Air control valve ) Also does anyone have any clue how much and wheres the best place to buy it...
From all the info ive gatherd here ive come to the conslusion thats what i need.. when its cold out side and i start my car up the idle gos up and down and up and down. I cleaned it out not to long ageo.
thanks for any help
Old Dec 20, 2003 | 01:49 AM
Kristo92's Avatar
Hey, I had this same problem with my integra. Is your car heavily modded? Try unplugging the IAC, and see if the idle smooths out. If so then your IAC is screwed up. If it still continues you probably have a vacuum leak. Before you do anything with the IAC though, i would check to see if you have any vacuum leaks. They have been known to cause a bumpy idle.
Old Dec 20, 2003 | 06:39 AM
specalk's Avatar
so i just unplug the grey connect clip then, this only happens when its cold outside, its just annoying and i hate it when im driving down the road with a nice looking car that soulds like its about to blow up.
all ive got donw to my car engine wise is intake and header
Old Dec 20, 2003 | 08:55 AM
specalk's Avatar
hey kristo92 i did what you said, i unpluged the IAc and the idle was very steady no ups and downs but i did get a check engine light when i did that.. so does that mean its time to change the IAC, also how much do you think it cost to get one and is it a simple bolt off bolt on swap or do i need to have something adjusted.
Old Dec 20, 2003 | 01:43 PM
Kristo92's Avatar
Through the Honda Automotive parts website a new IAC i believe costs around $150. There are 2 bolts i believe on the Iac that hold it on, and then like 3 hoses. Just take the hoses off, and then the 2 bolts, and the IAC should come right off. Spray the IAC down with brake cleaner, and that should clean off any residue that would be making the car have a jumpy idle. Also did you check for any vacuum leaks? Hope this helps. I would clean the IAC before you go out, and purchase a new one.
Kris
Old Dec 20, 2003 | 05:37 PM
superturboprelude's Avatar
Default Re: (Kristo92)
hi
where is the iac located ?
Old Dec 20, 2003 | 06:15 PM
Kristo92's Avatar
The IAC is located on the intake manifold. It has two bolts going into it, and i believe three hoses coming in, and out of it. Look for a black cylinder sorta shaped like a film canister. This is part of the IAC and will lead you to the full IAC. It is very easy to take off, and just cleaning it with brake cleaner usually solves any problems.
Modified by Kristo92 at 8:49 PM 12/20/2003
Old Dec 20, 2003 | 06:20 PM
Cottonwoodz's Avatar
It on the front of the intake manifold, bolted on the intake plenum.
Old Dec 20, 2003 | 06:25 PM
specalk's Avatar
Default Re: (superjunprelude)
The honda dealership did this a while ageo about 2 years ageo, i did it again during the summer.. can this valve go bad, also is this a common problem with this valve going bad..
I did what you said when i had the car running the idle was going up and down and up and down so i disconnected the grey connector for the IAC and the idle was steady. I did not check for any vacume leaks, i donot know how
Old Dec 20, 2003 | 07:51 PM
Kristo92's Avatar
When i thought my IAC was bad i went to the honda dealership to order a new one, and the lead mechanic told me in the ten years he has worked there he has only seen one other honda with this problem. I bet you have a vacuum leak, or your alternator is going out on you. For now until you can get the car fixed, just leave the IAC unplugged. Yes you will get a CEL, but at least your idle wont be going crazy. Let me clarify what is going on with your car.... When you turn the car on the idle jumps up and down? Does the idle jump from like 800 to 1500 and just keep on jumping up and down?
Old Dec 20, 2003 | 09:22 PM
del_parker's Avatar
Default Re: What to do with installing a IAC valve (specalk)
i just blocked mine off so air couldn't bypass, problem solved.
Old Dec 20, 2003 | 11:20 PM
I will guarantee 80% percent of the people with the idleing problem, have the idle screw on the throttle body turned too far out..
Old Dec 21, 2003 | 07:06 AM
specalk's Avatar
Default Re: (Cottonwoodz)
u can block it off
Old Dec 21, 2003 | 11:37 AM
Default Re: (specalk)
well i have a similar problem but it only happens in the morning when i first start the car and let it warm up the idle would jump gradually though no rapid the idle stop doing that when the car is fully warm and some times the car at idle it eiter be at 900 rpms to like 600 rpms wierd i dont know why it idles so low?
Old Dec 21, 2003 | 08:57 PM
vinuneuro's Avatar
Hey man, I had the same exact problems with the exact symtoms you have. When I had the Fast Idle Valve replaced, all the problems went away. By the way, 600rpm is a reasonably normal idle speed.
Old Dec 23, 2003 | 10:17 PM
Default Re: (vinuneuro)
where is the fast idle located?
Old Dec 23, 2003 | 10:47 PM
del_parker's Avatar
attached underneath the throttlebody.
Old Dec 24, 2003 | 07:13 AM
99lude's Avatar
by unplugging, do you mean just unplugging the grey connector? or removing the entire thing from the intake plenum?? and how do you check for vacuum leaks??
i have idle problem too, but when car is warm...?
Old Dec 24, 2003 | 09:09 AM
specalk's Avatar
Default Re: (99lude)
yes i had the car running then i disconnected the grey connector, youll get a check engine light so youll have to reset the ecu by pill the radio fuse or dissconnecting the battery.
I also to a blower and disconnected the hose from the IAC and the fast air valves while it was on the car not running and blew out the gunk, someone at work told me to do this because it gets a build up in there and it can cause the valves not to work like they should.
I think my pvc valve is not good i shake it and cannot hear the ball inside.
Im not sure how to check for vacume leaks i had a tech at work do it for me and he said it was allgood, ill ask him monday how he did it
self_made
Apr 10, 2021 02:25 AM
fano
Mar 4, 2011 11:39 AM
Ge-money
Aug 7, 2006 01:05 PM
devonic
Sep 26, 2003 08:55 AM
hondafrk
Oct 1, 2002 04:03 AM
