LS/VTEC HEADSTUDS?
Old Dec 19, 2003 | 04:25 PM
freezerburnv2's Avatar
Default LS/VTEC HEADSTUDS?
I'm getting Headstuds for my LS/VTEC They moved the dowl pins to fit the LS block so I should get B18 LS Head studs or B16 Head Studs?!?
Old Dec 19, 2003 | 05:18 PM
torr's Avatar
Default Re: LS/VTEC HEADSTUDS? (freezerburnv2)
this is what i was told
ls- too long, si- too short, gsr- too perfect for words.
so i got arp gsr headstuds, from rocket back in da day.
Old Dec 19, 2003 | 06:01 PM
Kendall's Avatar
Like torr said, get GSR studs, they will fit fine.
Old Dec 19, 2003 | 07:22 PM
X2BOARD's Avatar
Default Re: (dc231)
Gotta get the GSR's... LS/Si won't fit...too short....
Old Dec 19, 2003 | 11:06 PM
Ls Might be too long but will they work? Cause damn it money was already blown. if they are too long think a machine shop could lengthen the threads?
Modified by freezerburnv2 at 12:42 AM 12/20/2003
Old Dec 19, 2003 | 11:41 PM
Kwuaymaikrup's Avatar
The dowels don't have anything to do with the headstuds. Just buy the GS-R ones.
Old Dec 19, 2003 | 11:46 PM
Default Re: LS/VTEC HEADSTUDS? (Kwuaymaikrup)
I've already got these on the way
http://cgi.ebay.com/ebaymotors...18276
So they won't work with my LS/VTEC? Am I screwed?
Modified by freezerburnv2 at 3:16 PM 12/20/2003
Old Dec 20, 2003 | 02:19 PM
Bump?
Old Dec 20, 2003 | 02:48 PM
quik1's Avatar
Get GSR headstuds ls ones won't work like everyone else said.
Old Dec 20, 2003 | 02:59 PM
Default Re: LS/VTEC HEADSTUDS? (quik1)
well they are already on the way, so guess they are up for sale... DAMN IT
Old Dec 20, 2003 | 05:31 PM
Jaker's Avatar
Wow! You paid alot for those studs. You could order extra washers from ARP to make the longer studs work. The ARP washers are hardened steel, and will work fine for your application.
Old Dec 20, 2003 | 06:11 PM
DVS_EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freezerburnv2 &raquo;</TD></TR><TR><TD CLASS="quote">Ls Might be too long but will they work? Cause damn it money was already blown. if they are too long think a machine shop could lengthen the threads?
Modified by freezerburnv2 at 12:42 AM 12/20/2003</TD></TR></TABLE>
now, don't go and modify nothing, just buy new gsR head bolts, don't use old ones... and if your still going to purchase the ARP's, make sure you get the ones for the ACURA INTEGRA GSR "VTEC"... Ok, i hope that helps...
holla'
Old Dec 20, 2003 | 08:56 PM
veganej's Avatar
gsr works like a glove, what im gonna use when i complete my frankenstein
Old Dec 21, 2003 | 05:07 AM
Default Re: LS/VTEC HEADSTUDS? (veganstraightedge)
how much for the washers to make this work? where do I get them?
Old Dec 21, 2003 | 11:22 AM
Jaker's Avatar
From the manufacturer of the studs. ARP.
Old Dec 21, 2003 | 12:36 PM
AzG35's Avatar
Default Re: LS/VTEC HEADSTUDS? (Jaker)
The reason that LS studs won't work, is that the LS head has 4 (or 2, can't remember) raised sections for the head bolts. So 4 (or 2) are too long for a LS/VTEC. Deck height is the major reason for this, GSR, LS, b20, and ITR are all 7mm taller than B16's
Old Dec 21, 2003 | 09:40 PM
dohcnotec's Avatar
on the arp website they have b18a head studs at 11mm and they have the gsr head studs at 11mm toooo....so
Old Dec 22, 2003 | 07:43 AM
AzG35's Avatar
Default Re: (dohcnotec)
11mm wide maybe? But they don't say how long they are
Blackack26
Sep 1, 2005 07:51 AM
mxler8
Jul 27, 2004 07:57 PM
HondaSP
22
Jul 8, 2002 08:48 PM
integra81
Nov 22, 2001 04:11 PM
