Backlight & Instrument light fuse problem!
Old Dec 19, 2003 | 03:09 PM
dookieface's Avatar
Default Backlight & Instrument light fuse problem!
I keep replacing my fuse for the back/instrument light, but it keeps burning out. What can be the problem? I replaced them with a 10a, 25a, 15a fuses and they all burnt out. Is there some kind of common electrical problem that i can fix? Oh yeah i have a Civic 94 LX
Old Dec 19, 2003 | 05:20 PM
nsxmatt's Avatar
Default Re: Backlight & Instrument light fuse problem! (dookieface)
If you keep blowing fuses chances are you may have a short. Pull the cluster and check the bulbs.
Old Dec 19, 2003 | 05:49 PM
Kendall's Avatar
My friend John had all sorts of problems with fuses blowing. Upon investigation it was just a short in the system. Check it out real good.
Old Dec 20, 2003 | 12:32 AM
2+2=5's Avatar
Default Re: (dc231)
you are not helping by putting a higher rating of fuse, if you put a big enough fuse in it, sure it would blow, it just allowing whatever in the system to fry up.
yeah, pull it out and check for short or bad contact points
Ryanb525
Jul 27, 2014 12:17 AM
dansaleen_04
Jul 22, 2013 11:19 AM
NoNOSgsr!
Apr 2, 2005 11:19 AM
lYellowDragonl
Jul 11, 2004 08:48 PM
