VTec Kicks In Too EARLY??
Old Sep 22, 2001 | 03:20 PM
Bklyn TSi's Avatar
Banned
Default VTec Kicks In Too EARLY??
Hey, I ran an LED to the VTec solenoid next to the valve covers and placed it behind the gauges, it lights up whenever my VTec kicks in..... too my surprise, it comes on every gear at 2500 RPM?? No VTec controller or anything... would it be the previous owner of my car programmed it this way? Would this hurt the car since VTec requires lotsa oil pressure?
Old Sep 22, 2001 | 03:34 PM
Ricehornet's Avatar
Default Re: VTec Kicks In Too EARLY?? (Stony TSi)
if VTEC engages too early, the valve opens too long and what not, so the compression in each cylinder will not be as great due to blowby. Reason for the high lift, duration cams is due to the inertia of the air, at high rpm, you have to open earlier and longer to fill the cylinders, using the same cams at low rpm would result in imporper filling of the cylinders, sure you'll get air in but the piston is already moving up, releasing some air before it closes.....
it's weird because VTEC is dependant on a couple things to engage, are there any electronics in the car, ECU and what not?
Perhasp you rigged the LED incorrectly.
Old Sep 22, 2001 | 06:50 PM
Leo95SE's Avatar
Default Re: VTec Kicks In Too EARLY?? (Ricehornet)
ok.. mr grasshopper is way too complex for me
first off - if vtec engages that early, youll know b/c itll bog like hell...
also,just punch it and se if vtec kicks in (4800). you should feel or hear it..
all in all.. i agree with mr hornet - wired wrong..
good luck
Old Sep 23, 2001 | 06:52 PM
88_SC_CRX_Si's Avatar
New User
Default Re: VTec Kicks In Too EARLY?? (Leo95SE)
It could be kicking in the second stage of VTEC at 2500rpm. Thats why his light is coming on...
Check this out:
http://integra.vtec.net/engine/vtec.html
[Modified by 88_SC_CRX_Si, 7:53 PM 9/23/2001]
Old Sep 24, 2001 | 12:04 AM
max's Avatar
max
Default Re: VTec Kicks In Too EARLY?? (88_SC_CRX_Si)
VTEC-E is only on Civics HX, i think. but yes, IT does kick in at about 2500
Old Sep 24, 2001 | 01:17 AM
martini's Avatar
Just wanted to make a point to Ricehornet..That would be called Valve overlap, not blow-by.
Blow by is where your piston rings can't contain the compression, and it just blown by.
but yes, I concur...it is probably wired incorrectly..
[Modified by martini, 2:18 AM 9/24/2001]
Old Sep 24, 2001 | 06:15 AM
New User
Default Re: VTec Kicks In Too EARLY?? (martini)
Three Stage VTEC
First of all, despite being 16 valves, there is really only one cam lobe for operation in the first two stages. This is supplemented by the high lift center lobe (like in the normal DOHC VTEC). The second intake valve rocker, however, simply rides along a zero lift ring in place of the usual lobe on the cam shaft.
To activate the second stage at 2500 rpm(both valves opening), oil pressure is diverted into a channel that drives a pin which connects intake valve rocker #1 with #2. Now, both intake valves are being operated in unison. This is perhaps not quite as ideal as a little valve stagger (as seen in the DOHC VTEC apps), but sufficient enough for good power.
To enter the third stage, at 6000 rpm, oil is now allowed into a second channel connecting all the rocker arms. This oil drives a pin which connects the linked #1 and #2 rockers to the center lobe actuated #3 rocker which is, of course, the high lift and duration mode.
Where does it say anything about about VTEC-E with DOHC?
O/T - If you do not call it blow-by when valve-overlap occures if FI, what do you call then?
[Modified by 88_SC_CRX_Si, 7:18 AM 9/24/2001]
Old Sep 24, 2001 | 08:36 AM
jebarco1's Avatar
New User
Hey, all yall vtec-rs oil is a important part of vtec. Some make sure your oil is clean dont want to get the soleniod stuck open.
Old Sep 24, 2001 | 08:41 AM
jebarco1's Avatar
New User
Default Re: VTec Kicks In Too EARLY?? (jebarco1)
yea he got a HX model have to be. Oil pressure isnt up to even take advantage the vtec, second my mans vtec soleniod got stuck open and the once it reached pressure it locked the third valve about 4000 and it just boggged tell like 6000 which was a hard problem to fix. Luckly i had a GSR head that i was shipping out , and tried the soleniod on it, and it worked. If not for that we would have been lost. Be he did change his oil like talking about it , but what can you do with spoiled hard head kids with deap pocket parents.. **** he threw a rod, and parents just bought him a RSX,, crazyness.
Old Sep 24, 2001 | 12:05 PM
max's Avatar
max
88_SC_CRX_Si, there is no DOHC VTEC-E engines. they are all SOHC and made for fuel economy in mind only.
Old Sep 25, 2001 | 12:07 AM
New User
Default Re: VTec Kicks In Too EARLY?? (max)
I know there is no VTEC-E in a DOHC. hehehe In the orginal post, he was asking why his light was coming on at 2500. I said it was the second stage. Some one else mentioned the VTEC-E.... Thats why I did the "quote". In my question "Where do you see DOHC VTEC-E mentioned....
[Modified by 88_SC_CRX_Si, 1:11 AM 9/25/2001]
Old Sep 25, 2001 | 08:04 AM
max's Avatar
max
hmm, nevermind
TheBook
Nov 14, 2012 08:40 AM
lmiguelvv
Oct 19, 2004 06:55 PM
JDM00SI
Jul 18, 2004 11:06 PM
Type-Rare#1248
Dec 25, 2001 12:17 AM
