B16 parts questions
Old Dec 19, 2003 | 11:09 AM
Civic44's Avatar
Default B16 parts questions
I now have a B16a CRX that I bought already swapped. I have some parts questions since I'm going racing and need to freshen things up.
Which axles do I need? Which axles if I go to Integra brakes?
Which oem clutch?
Which oem flywheel?
Which intake tube?
Which header? any B-series?
Thanks.
Old Dec 19, 2003 | 11:23 AM
EL Vap133's Avatar
Default Re: B16 parts questions (Civic44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic44 &raquo;</TD></TR><TR><TD CLASS="quote">I now have a B16a CRX that I bought already swapped. I have some parts questions since I'm going racing and need to freshen things up.
Which oem clutch?
Which oem flywheel?
Which intake tube?
Thanks.
90-93 Teg axles for either stock or Teg brake setup.
Clutch, I'm assuming you have a JDM cable tranny, you can use 90-91 Teg clutch.
flywheel, I believe you can use any B-series flywheel (someone correct me if I'm wrong)
Intake, you can still use a crx intake unless you go with an AEM setup.
Header, any B-series header will bolt up to the head, maybe a 00 Civic Si header will fit better though...
Mr Furball's Avatar
Which oem clutch?
Which oem flywheel?
Which intake tube?
Thanks.
Axel's=90-93 integra
clutch= what trans do you have? Y1, YS1, there are two or three other, I can't think of them right now.
Flywheel=again what Trans. and ask for the same one at Honda
Intake Tube= there are allot out there, AEM, Iceman, J's Racing, Nakayama, K&N, lots of others + do you want cold air or short ram
Header=Again, lots to choose from, DC, ANR, Toda, Mugen, JDM 4-1, SMSP, lots of others, what do you want again, 4-1 or 4-2-1, all are B series.
Do you have a race license yet?
Old Dec 20, 2003 | 06:59 AM
Civic44's Avatar
Default Re: B16 parts questions (FURBALL B-16)
Yeah, I already have a race license, I've been racing an EF hatch with a D16Z6 with EMRA and won the enduro championship in my class this year with it:
I recently picked up the B16 CRX really cheap. I'm putting the B16 and the Koni shocks from the CRX in the hatch and putting the D16z6 and KYB shocks onto the CRX (I want to continue racing the hatch, it's a personal preference). I don't know which tranny I have... the guy who sold me the car told me it was an older B16a and it's a non-lsd tranny that came from the same car as the engine. It tops out at about 55-57 mph in 2nd gear if that's any help, about 87-89 mph in 3rd (at 8200 rpm both).
Old Dec 20, 2003 | 08:25 AM
RCautoworks's Avatar
Parts that say del sol by them, you can usually get them for a 00 si also. A lot of part stores confuse the del sol dohc vtec with the del sol sohc vtec. So just make sure you getting it for the right car.
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
***** Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets -8- 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
Old Dec 20, 2003 | 08:36 AM
Civic44's Avatar
Default Re: B16 parts questions (90blackcrx)
Wow, that's quite a list. Thanks.
Old Dec 21, 2003 | 08:03 PM
type Gendy's Avatar
Big bob always hooks the list up
JWhip1
Transmission & Drivetrain
14
Sep 20, 2009 09:56 PM
egizzle8
Jun 28, 2005 08:46 AM
Grnade
Sep 8, 2004 01:00 PM
BigIslandBoi
Apr 29, 2004 10:42 AM
