Is it worth getting GSR camshafts?
Old Dec 19, 2003 | 10:00 AM
Se-rv-Tak's Avatar
Default Is it worth getting GSR camshafts?
I was curious to know, on my CRVtec is it worth it running the GSR intake cam and the stock b16 exhaust cam? or will I be fine with just the b16 cams? Or will it benefit me more to use the GSR intake cam?
Old Dec 19, 2003 | 11:31 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: Is it worth getting GSR camshafts? (Soon2B18Boost)
i doubt you would see very much gain from the change. why not just save up for some itr/ctr or aftermarket cams?
Old Dec 19, 2003 | 11:33 AM
WhiteEG6's Avatar
IM running an LS/VTEC with a B16 head. I swaped out the cams for GSR units. It make a considerable difference in the power range
Old Dec 19, 2003 | 12:19 PM
eyeamvic's Avatar
The guy I sold my GSR cams to was happy with them in his b16a. He said it was a pretty big difference.
Old Dec 19, 2003 | 01:28 PM
B16OnTop's Avatar
Default Re: (eyeamvic)
yea save up the extra $100 and go with ctr/itr's
Old Dec 19, 2003 | 05:18 PM
Se-rv-Tak's Avatar
Default Re: (B16OnTop)
well it's $30 for the intake cam and cam gear?
Old Dec 19, 2003 | 05:27 PM
Kendall's Avatar
If it's only $30, then go for it. But you'll still be much happier with some Type R cams.
Old Dec 19, 2003 | 05:40 PM
Se-rv-Tak's Avatar
Default Re: (dc231)
I know that, I wish had $2-300 for a set of CTR camz, but right now I can get JUST the intake GSR camshaft with cam gear for about $30. So that's why I wanted to know if it is worth it or not.
Also while I'm on the subject of GSR cam's, is there a way of identifying the cam to make sure it is really a GSR?
Old Dec 19, 2003 | 05:48 PM
Kendall's Avatar
Go ahead and get the GSR cam for $30, it's more than worth it. In fact IM me later if you want to sell it, I can use it. The GSR cam should be stamped P72 for identification purposes.
Old Dec 20, 2003 | 08:52 AM
Se-rv-Tak's Avatar
Default Re: (dc231)
ok cool deal. thanx guys. I will sell the GSR cam after I get a set of CTR cams...he he he.
underpressure02
Oct 5, 2006 03:03 PM
unclepowers
Sep 23, 2005 10:27 AM
tmekjian
Apr 30, 2003 06:03 PM
Houston Hatchback
Apr 21, 2002 10:52 PM
