Definitive JDM folding mirrors wiring / install guide into 4gen prelude
Old Dec 19, 2003 | 01:59 AM
wstef's Avatar
Default JDM folding mirrors wiring / install guide into 4gen prelude
Finally I have found solution to install this nice toy. Also, a lot of thanks to elnoyl for his help.
I decided to write this guide as nowhere in the net I haven't found a guide for prelude...
So, let's go to the game:
Nomenclature I used:
LHD - left hand driven car
RHD - right hand driven car
oem - our components
JDM - japan components
1. Mechanical
The very important thing is to say that JDM mirrors are from RHD cars. The mirrors are in fact the same, but the supporting elements not. They look almost as LHD ones, but the angles of neutral mirror position are different. Also, I have never thought before that even in ours LHD cars the left and right mirror supports are different. It can be good seen if you see your car from a higth building. The rigth mirror has bigger angle that the left mirror. It is because driver is sitting on left side of car. In Japan it is reverse.
If you will put directly RHD mirrors into a LHD car (in neutral position, into middle of regulation range) you will see only a side of your car into right mirror and some landscape into left one... If you will try to adjust the mirrors you will get a little better view, but you will achieve the extreme points of regulation range. It is neither nice, neither safe. Some people try to improve the viewing range by glueing a small round wide angle mirror on the corner of mirror glass. It is not nice too...
My idea was finally to leave all exterior parts from my oem mirrors as they are - in such case you will not need to repaint the jdm mirrors - almost always you will get them into different color - and to swap only the "skeletons" - the only thing that mechanically differs oem and JDM ones...
To do this first you have to demount oem mirrors from the car. Then you disasemble completely all mirrors you have: 2 JDM and 2 oem:
- disassemble conectors - a needle or an office binder is a very useful tool (note the position and colors of wires in the connector), take off black gummy weatherstrip, take off a small screw holding the wire harness into the support,
- take out 4 screws fixing mirrors to their supports: 3 are located under the mirror, the 4th one is located from support side,
- disassemble mirror from support, carefully pulling the wire harness,
- take off a mirror glass and a small black unpainted side cover. The side cover is held by two small hatches. the hatches are visible if a glass is taken off. Use a long small long screwdriver to push them when pulling the cover,
- when the black cover is extracted you will see 2 small screws - take them off
- take off 3 bigger screws holding the mechanism into mirror plastic cover (visible when mirror glass is taken off).
The mechanism is extracted. Just swap the jdm mechanisms into your oem mirrors.
Fix frankenstein mirrors on oem supports. In my case assembled oem mirrors with JDM mechanisms have not wanted to get directly the original oem supports. There are 2 blocking things:
1. Our friends from japan have made a small dirrerence in shape (almost invisible by eye, but well blocking), especially in proximity of 4th screw (the one from the support side). Take off some metal from the part that enters to the support - I used a grinder to take off maybe 0.5 - 1.0 mm of metal. But you will see yourself if it enters or if it is necessary to fileing some material more).
2. There is also a small positioning point on the oem support (does not exist on jdm support), the JDM mechanism has the same one in the same place (but oem mechanism has not) - you cannot have both - just cut one of them - I have cut a one from oem support (compare two supports and mechanisms to see where the points are).
Fix the wire holder and weatherstrip. Install jdm connectors. Mount assembled mirrors on the car.
Now you have jdm mirrors LHD version.
2. Electrical
First, I want to say, that I haven't found any possibility that JDM mirrors could operate automaticaly when you use your e-brake, switch off ignition, open door, etc. as it may be suggested in many places in the net. Looking the components and redesigning the wiring diagram (I didn't get any documentation with the mirrors) I am almost 100% sure that in JDM solution they operate ONLY if user press the fold button.
You should get with mirrors two toys: a JDM switch with fold button and a relay.
- button: the only difference is an additional blue/yellow wire. Extract this wire from jdm connector and put it into your oem one. By pressing the buttom +12V is given to the blue/yellow wire. In other words the relay is activated by a positive pulse (this blue/yellow wire goes directly to relay).
- relay: a big challenge, especially as it doesn't exists outside of jdm and is hard (=expensive) to get... my greatest fear was not to blow out the relay by an incorrect wiring...
The relay for prelude is different of civic or integra relay. It has 7 wires instead of 5. The colors and connections are (thanks again to elnoyl):
blue/white - right mirror fold motor,
red - right mirror fold motor,
blue/yellow - from the switch,
black - ground,
white/yellow - power (+12V constant)
blue - left mirror fold motor,
blue/red - left mirror fold motor.
The white/yellow wire should be constant +12V powered to assure the correct fold operation when ignition is cut (ex. you push the fold button and immediately take off the key from ignition). If it would be not constant but accessory/ignition on powered you would risk to take off the key faster that the mirrors would fold completely.
The relay is current-sensitive, there are no end switches in mirrors. The power to the mirror is cut off when the relay detects a highter current.
In the same way, if you want to have mirrors operated by your car alarm, you should provide a +12V pulse when arming/disarming the alarm to the blue/yellow wire - many alarms has this option.
That's all...
Modified by wstef at 9:17 AM 6/16/2004
Old Feb 5, 2006 | 03:58 PM
danerr's Avatar
Default Re: JDM folding mirrors wiring / install guide into 4gen prelude (wstef)
excellent write up. this is on my to-do list.
FYI: if that honda relay cant be tracked down, this is a simple circuit to put together, from any electronic store and someone who knows simple circuit design.
Old Mar 27, 2006 | 05:32 PM
jdmnash's Avatar
Default Re: JDM folding mirrors wiring / install guide into 4gen prelude (danerr)
I have the wiring diagram if anybody needs it...
Old Mar 28, 2006 | 06:11 AM
iakona's Avatar
so very awesome...
Old Aug 18, 2006 | 02:57 AM
jazmie's Avatar
Default Re: (iakona)
hi
can give me wirting diagram for EG car especially for foldable mirror.....thanx
Old Aug 24, 2007 | 06:37 PM
cfran55's Avatar
Default Re: (jazmie)
anyone have pictures or where did you exactly wire your ground and positive wire to
Old Aug 25, 2007 | 08:55 PM
crj_lll's Avatar
Default Re: (cfran55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cfran55 &raquo;</TD></TR><TR><TD CLASS="quote">anyone have pictures or where did you exactly wire your ground and positive wire to</TD></TR></TABLE>
http://www.preludezone.com/showthread.php?t=745
Old Nov 10, 2008 | 10:56 AM
Ludetr's Avatar
Default Re: (crj_lll)
hi everyone, anyone can send me the 4th gen. wiring .Thanks
Old Dec 7, 2008 | 04:42 PM
Bludger's Avatar
Is there any such DIY for dc2r Integra folding mirrors?
If so, can someone please link me
thanks
Old Mar 19, 2009 | 07:14 PM
hondawagonman's Avatar
will that diagram work on a 95 honda accord ?if so then i could use that diagram id be greatfull for that info thanks
Old Mar 25, 2009 | 06:53 AM
dstylez's Avatar
New User
Default Re: Definitive JDM folding mirrors wiring / install guide into 4gen prelude
Awesome, I'm going to do this for my 5th gen this week, hopefully its similar.
Old Mar 25, 2009 | 09:18 AM
93prelude615's Avatar
Please post this up on preludepower.com if you havnt already.
It's great and will probably get a lot of attention on there...
Old Mar 25, 2009 | 10:22 AM
oranginal's Avatar
I think my passenger side is broke after 6 months of working perfectly. I can hear it trying to fold but nothing happens and my drivers side is fine. any suggestions of what i can check or where i could get one motor/mirror?
Old Mar 25, 2009 | 11:34 AM
MLBZ521's Avatar
This thread is from 2003 guys........
Oranginal, try pushing the button twice, does that make it work?
My drivers side acts funny also.
Old May 11, 2009 | 11:58 AM
cfran55's Avatar
hey guys i have an autopage 900 how would i wire this up to my alarm?>
Old May 11, 2009 | 06:08 PM
oranginal's Avatar
nope i tried pressing it twice still no luck. some times i feel they go off track then they start to work again but now all i hear is the motor spinning and the mirror doesn't want to move at all. i guess some day i should probably take it apart and look at each part closely.
anyway for the alarm guy above, i'm sure you could just splice an option trigger from your alarm (usually a white wire) into the wire that the mirror folding button triggers sine both would be a momentary pulse.
p.s. if anyone has a driver's side motor extra pm me
Old Sep 24, 2010 | 11:33 PM
archebald23's Avatar
i think this is a nice video..what do you think?
Old Sep 25, 2010 | 09:15 PM
H23SIR's Avatar
I got the folding mirror for about 4 years already. I using everything from the jdm part. I should swap out the jdm covers and use oem covers, but too lazy. you can use remote /key pop control from the alarm to fold when armed. just like to roll up windows.
per4mnc lude
Apr 19, 2006 03:19 PM
pez1
Jan 12, 2006 06:54 AM
Milano_EH3
Sep 30, 2004 12:25 PM
ef93si
Jan 19, 2004 01:02 PM
