cross country in a teg?
how reliable would it be for a LS with about 134k miles on it, to drive from ca to fl? what should i look for in terms of keeping the engine safe while driving with that kind of a distance?
LS motors are pretty strong and im sure it can handle it easily. Just make sure you change your oil before you go because you are traveling around 2500-3000 miles if im correct. Oh yeah make sure your spare tire has right amount of pressure incase you get a flat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milton »</TD></TR><TR><TD CLASS="quote">I recomend a complete tune up. spark plugs, engine coolant, oil.. etc....Tires should be in almost perfect condition. Ull be cool. </TD></TR></TABLE>
im blown rite now...
If you can, bring some extra fluids just in case. I'd also try to bring some socket wrenches, just in case. Good luck!
I just went from Kansas to LA in my '93 (loaded with most of the **** I own ~300 lbs.) with 125K miles. Absolutely no problems whatsoever. Just change the oil, load up the trunk with tools, a quart of oil, some brake fluid, a properly inflated spare w/jack and some Techron concentrate for every tank of fuel.
My teg went on a road trip two years ago when i first bought the car.
Took a drive from NY to Sarasota florida with numerous stops through virginia, georgia, NC, SC and FL.
This is basically what i did:
changed Motor Oil / filter .
changed Airfilter
changed Spark Plugs
changed Clutch Fluid
changed Brake Fluid (bled the brakes)
Checked Brake pads (still good)
Added Wiper fluid
checked master cylinder and steering fluid levels
flushed coolant (first flush after i purchased the car)
checked tire pressure
checked tires for damage or rips
checked spare tire and tools.
Hope this helps. Take advantage of the cruise control if you have it. good luck
changed Airfilter
changed Spark Plugs
Added Wiper fluid
Guest
Posts: n/a
just drive from pennsylvania to utah. car worked fine. nothing went wrong except for those god forsaken kansas highway patrol! lol you will be fine, just take a qt. of mobil 1 and you will be cherry...just dont
and drive we dont need another post about someone wrecking their teg
you'll be fine. a lot better off than most other cars. just bring some good tunes... and a friend if you can. and the emergency stuff.. duct tape, fluids, flashlight, blankie, etc... and everything else ppl have said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC »</TD></TR><TR><TD CLASS="quote">My teg went on a road trip two years ago when i first bought the car.
changed Airfilter
changed Spark Plugs
Added Wiper fluid
what is clutch fluid?
auto tranny fluid?
fluid in the differential in a manual?
changed Airfilter
changed Spark Plugs
Added Wiper fluid
auto tranny fluid?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99silverbullet »</TD></TR><TR><TD CLASS="quote">its the small little resavor(wrong spelling I'm tired) by the brake one.</TD></TR></TABLE>
oh yeah forgot what year we were talkin about here.. stupid hydro trannies
I'll be driving all over the country in mine. I'll be going to Atlanta, Oscoda MI, Ft. Worth TX, Virginia, and this is all from St. Louis. Plus, when I get there I'll be racing the car and then turning around and driving home.
mikeycivic
15
Jul 17, 2006 12:52 PM
sleepystyle
Apr 12, 2006 10:02 PM
