Prelude is leaking
that MIGHT be it. There is a drain hole at the front and back of the sunroof track. The one on the back runs down the back pillar by the rear window. I had mine clog up and it dumped water all in the back floorboard and into the trunk. KEEP THIS IN MIND:
All leaks are different.
If it's not the drain tubes, check the taillight gaskets, I've had leaks from both of those spots, though, and sunroof tubes are easier to check.
Greg
Greg
well, I think I fixed it. The tube ends are found in the trunk right next to the tire wells. I had to take the lining of my trunk out. The tube ends are clamped to a naros opening which doesn't let dirt out so it plugs up. I trimed them to there was a bigger opening so if anymore dirt goes down it'll dump it. Thanks, JG, for the idea.
bdb
Oct 16, 2003 12:56 PM
BoostedH23a1
Sep 17, 2002 06:22 AM
