Ok...I got my distributor finally but there is another problem!!
Old Dec 18, 2003 | 06:45 PM
girlieracerk's Avatar
Default Ok...I got my distributor finally but there is another problem!!
I posted earlier about the distributor going out in my car. Well I got one and put it on today and it started right up. The problem is after I let it run for a few and pushed the gas a little it went dead and now won't start and acts like it did before I even put a distributor on it. I don't know what to do. Please help I haven't drove in like 2 weeks.
Old Dec 18, 2003 | 07:16 PM
xerox445's Avatar
did you get the whole distributor or just cap and rotor? was the coil replaced?
Take out your sparkplug wires one at a time and put a screwdriver into the hole...hold it over something that is metal and a ground. If you see an arc you are getting spark...
if your getting spark, then check fuel. sounds like that may be the problem at hand.
Old Dec 18, 2003 | 09:55 PM
psi420's Avatar
Yeah, this sounds like an ignition module related issue.
Old Dec 18, 2003 | 10:12 PM
Default Re: (xerox445)
I got the whole thing and didn't replace anything just put the whole thing on. I don't understand how it cranked just fine and ran for a little bit then died. I was thinking where I tried to start it before it could have flooded it so tomorrow in the daylight I'm gonna check the spark plugs. On the original distributor I had got a new cap and rotor. You think maybe replacing the one on the original with the one I just got would help or not? (btw the one I just got came from a junk yard so it's not brand new) Thanks though for the help so far guys!!
roxy
theEFkid
Apr 9, 2012 05:43 PM
B16Turtle
May 28, 2009 01:03 PM
ILuvMyJdmDc4
Nov 27, 2007 04:43 AM
JDMBB2
Jan 25, 2004 09:17 AM
CivicBoi
Jul 12, 2002 08:57 AM
