what gear is this....
Old Dec 18, 2003 | 05:31 PM
HatchBox's Avatar
Skoobie no more...
Default what gear is this....
b16a1. what gear is this?
Old Dec 18, 2003 | 05:46 PM
jlicrx's Avatar
Default Re: what gear is this.... (ind3ciso)
starting at bottom, going up
1st - reverse (with straight cut gear) - 2nd - 3rd - 4th -5th
looks like you have a broken shift fork on 5th
Old Dec 18, 2003 | 08:16 PM
HatchBox's Avatar
Skoobie no more...
Default Re: what gear is this.... (jlicrx)
so the shitty gear is reverse?
Old Dec 18, 2003 | 08:23 PM
jlicrx's Avatar
yes, the one with the straight teeth is reverse
Old Dec 18, 2003 | 08:26 PM
HatchBox's Avatar
Skoobie no more...
what would cause that to wear down so much? there is ALOT for metal flakes in my tranny
Old Dec 18, 2003 | 08:38 PM
Red_Si's Avatar
i don't know but i would just like to note that the inside of trannys scare me!
Old Dec 18, 2003 | 08:45 PM
HatchBox's Avatar
Skoobie no more...
Default Re: what gear is this.... (Red_Si)
me 2, especially when there fucked up,
Old Dec 18, 2003 | 09:18 PM
X-Static's Avatar
what happaned to your funny lil avatar?
Old Dec 18, 2003 | 10:03 PM
ndtITR's Avatar
that looks insane....it also scares me...
Old Dec 18, 2003 | 10:15 PM
HatchBox's Avatar
Skoobie no more...
Default Re: what gear is this.... (X-Static)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X-Static &raquo;</TD></TR><TR><TD CLASS="quote">what happaned to your funny lil avatar?</TD></TR></TABLE>
idk, did u like it? lol
Old Dec 19, 2003 | 05:44 AM
kranked91dx's Avatar
well on Honda car, the reverse is not synchronized, so if the car is mooving a bit and you'r trying to engage the reverse... you'll end up making some metal shave...
that's about it
Kranked,
btw... your 5th gear shifting fork ( the part's that is in the ring ) is broken, and yes this is bad... change it while your at it...
see ya
Old Dec 19, 2003 | 06:59 AM
USDM 4G VTEC's Avatar
thats the select ring gear that locks the first and second gear with the shaft so the car moves... basically thats what shifts gears
Old Dec 19, 2003 | 10:42 AM
crxfanatic's Avatar
New User
Looks like your 5th gear selector fork has a busted off piece, and said piece got all ground up in the tranny. If you're lucky, you can clean everything good, get a new shift fork, and be on your way.
Old Dec 19, 2003 | 11:06 AM
HatchBox's Avatar
Skoobie no more...
Default Re: what gear is this.... (crxfanatic)
how much would it be to repalce that? and how much to replace that gear?
Old Dec 19, 2003 | 06:36 PM
XrcR6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">what would cause that to wear down so much? there is ALOT for metal flakes in my tranny </TD></TR></TABLE>
Maybe I'm reading this wrong, but it kinda sounds like you think the reverse gear teeth are supposed to be cut like the forward gears (/////). Reverse is a straight cut gear like they said above (|||||). So it didn't actually wear from ///// to |||||. All the metal is probably from the broken shift fork that got eaten up in the tranny. That should be all you need to replace, not reverse.
Old Dec 19, 2003 | 09:12 PM
HatchBox's Avatar
Skoobie no more...
Default Re: what gear is this.... (XrcR6)
im sorry but which one is the shift fork that is broken?
USDM-EK4*
Jun 5, 2007 09:33 PM
94Vtecluder
Oct 23, 2006 08:06 PM
jdm_DC2R
Mar 21, 2006 08:37 AM
torr
May 22, 2005 03:49 PM
gsrteg93
Apr 30, 2003 11:07 AM
