WOW.....two thumbs up for GM synchromesh
I had a nasty grind going into 5th gear.....put in gm synchromesh around 78000 mi. and now at 81500 the grind is gone. I had to double clutch for a while, that was the only way to get into 5th without a grind...but now it is like butter. i have a 2001 gsr....thanks for all the help....have some
on me
on me
"how much did they cost you + labor?"
civicsir94....i only chanded my trany fluid...it was something like $35 for three quarts and about 15 min. of my time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew01 »</TD></TR><TR><TD CLASS="quote">I had a nasty grind going into 5th gear.....put in gm synchromesh around 78000 mi. and now at 81500 the grind is gone </TD></TR></TABLE>
Thats great to hear, I have the same problem. I double clutch it too...
I just replied to an earlier post, about synchromesh. I was debating wether
I should give it a shot. I just switched to Honda MTF from 10-30 (90 g2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmydc2 »</TD></TR><TR><TD CLASS="quote">yes gm synchromesh is tranny fluid, like redline mt-90.
how on earth did you get grinding in 5th gear on a practically new car???</TD></TR></TABLE>
If the tranny is under-filled, it can cause 5th to grind since it's the last gear to get lubrication. The car MUST be level when you fill the tranny, if you fill it until it runs out the filler hole. If only the front of the car is up in the air, the fluid will start running out the filler hole after only about 2 qts. are in there. The proper amount is a little less than 2.5 qts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">
If the tranny is under-filled, it can cause 5th to grind since it's the last gear to get lubrication. The car MUST be level when you fill the tranny, if you fill it until it runs out the filler hole. If only the front of the car is up in the air, the fluid will start running out the filler hole after only about 2 qts. are in there. The proper amount is a little less than 2.5 qts.</TD></TR></TABLE>
yes there was the propper amount of fluid was in there....atleast when i took it out. Honda does all my service work....i have never had a problem with them before. The reason i have so many miles i am self employed and drive all over central FL, from day to day. I bought the car new with 7 milesin aprial 01....
Any GM dealer should have it. They always keep it in stock for their cars and for purchasing. w00t w00t to GM Synchromesh---> one of the best investments to your tranny..
i put this stuff in after countless ppl sayin to use it... I put it in with 108k on the OD... car has has it for over 8k in the last 6 months and it STILL shifts like butta.... it took about 1000k to get my grind to dissapear...
Napa carries the SAME stuff marked as their own. Same part number and everything, and 10 bucks cheaper...
https://honda-tech.com/zerothread?id=549469 before anyone asks me the part # agian... I need to keep it in my damn sig lol... its in there. Read all 5 posts if you wish, tons of ppl atesting to the fact that this is GOOD ****. You dont need the friction Modifier one, ONLY the Regular GM SynCromesh.
pcorad
Jul 28, 2008 05:42 PM
I got a little confused
