feeler guage..... did I buy the right one ?
Old Dec 18, 2003 | 05:03 PM
mtber's Avatar
Default feeler guage..... did I buy the right one ?
I burchased a craftsman 26 blade feeler guage.
It only does .13mm-.76mm or .005in-.030in
I know toda recommends something like a .2mm valve clearance is this true ?
Hence I would have the wrong tool.
What is the factory ITR valve clearance settings ?
Intake: 0.006 - 0.007 in
Exhaust: 0.007 - 0.008 in
Thanks,
John
Old Dec 18, 2003 | 05:04 PM
mtber's Avatar
Default Re: feeler guage..... did I buy the right one ? (mtber)
Just read this on toda's site:
All TODA Racing camshafts must be tuned using TODA adjustable campulleys to attain maximum performance. Valve lash for all cams is 0.2mm cold.
Horseshit, looks like I need a better feeler guage.
Old Dec 18, 2003 | 05:08 PM
Dan GSR's Avatar
if you have .13-.76
how does .2 not fall in that range ???
Old Dec 18, 2003 | 05:11 PM
mtber's Avatar
I am a moron... I didnt relize .2 was the same as .20
Old Dec 18, 2003 | 05:13 PM
mtber's Avatar
Moderator, delete this post I am a moron :-)
Old Dec 18, 2003 | 05:22 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">I am a moron... I didnt relize .2 was the same as .20
LOL!!
Well, at least you owned up to it. Your first post confused the hell out of me. I guess you were thinking "point thirteen" then got messed up when Toda said "point two."
Old Dec 18, 2003 | 05:42 PM
Dan GSR's Avatar
Default Re: (Splat)
did you get the angled feeler guage?
you may still have the wrong feeler guage
the angled ones are longer and reach better than the straight ones
Old Dec 18, 2003 | 07:37 PM
mtber's Avatar
I purchased the check valve clearance offset 45 deg feeler guages :-)
Ive used this same set before to check valve clearance after installing cams in my b18b.
I have another q, where can I purchase a valve adjusting tool...
I know a lot of guys use a bent 10mm wrench... But I dont have access to one or a torch to make one...
I would rather use a snap on style tool then a torqe wrench to set the 10mm nuts to spec :-)
Any info on an aftermarket tool besides snapons would be nice.
Old Dec 18, 2003 | 07:54 PM
ArmyGreenITR's Avatar
Default Re: (mtber)
lol atleast you ownded up to that first question(we all have had one of thoose days),as for the second queston ask Eric(rainmanEk)my old roomate, he bought one but i cant rember where he got it.
Old Dec 18, 2003 | 07:58 PM
Dan GSR's Avatar
Default Re: (ArmyGreenITR)
http://www.sears.com/sr/javasr...93000
I have this set
works great and its cheap
Old Dec 18, 2003 | 08:04 PM
mtber's Avatar
Cool, you can use a screw driver with that set cause its "hollow"
btw... I know eric & chris ive met them a few times... I will ask eric if he knows where I can get a tool locally...
I might just buy the tool dan gsr posted :-)
Old Dec 18, 2003 | 08:06 PM
Dan GSR's Avatar
Default Re: (mtber)
you can get that set at most sears
If used the other sockets on some occasions as well
blykins
May 23, 2003 11:06 PM
Mike95lude
Oct 21, 2002 08:11 PM
GOLDENCHILD
Aug 12, 2002 12:14 PM
Maxi
Sep 27, 2001 01:54 PM
