Comp cams for Dohc Vtec
Old Dec 18, 2003 | 04:55 PM
Lysawy's Avatar
Default Comp cams for Dohc Vtec
Are these any good considering, The stage 1 cams feature 220 degrees of intake duration and 222 degrees of exhaust duration (@.50) will i have to change my T-body and intake mainfold for better flow any input would help its for a b16.. thank you
full info at
http://www.compcams.com/Techni...3.pdf
Modified by Lysawy at 9:06 PM 12/18/2003
Old Dec 18, 2003 | 05:13 PM
Lysawy's Avatar
Default Re: Comp cams for Dohc Vtec (Lysawy)
anybody with any info on this ..
Old Dec 18, 2003 | 05:17 PM
Kendall's Avatar
Comparitively there aren't a lot of people using comp cams with there Honda motors. Also a lot more people would be able to help you if you could get the specs on the lift, and the duration in measurements other than .50.
Old Dec 18, 2003 | 05:39 PM
Lysawy's Avatar
Default Re: (dc231)
Comp cams for b16,b18 vtec
duration
int. 260
exh. 266
Lobe lift vtec
int. .310"
exh .297"
valve lift (vtec)
int. .435"
exh .395"
centerline vtec
int. 100 degrees
exh. 106.5 degrees
Old Dec 20, 2003 | 07:36 AM
Lysawy's Avatar
Default Re: (Lysawy)
bump anybody got any info on this
zamrioo2
May 17, 2007 09:03 AM
bugster
Jan 28, 2005 10:18 PM
