what type of supplies for swap???
Old Dec 18, 2003 | 03:09 PM
99spanishGT
Guest
Posts: n/a
Default what type of supplies for swap???
ok i spun a rod bearing in my old motor and im just swaping in a short block, what gaskets will i need and fluids, also for the head gasket is there a special type i should get??? anything i will need or stuff to check for because of what happened, any help is appreciated
Old Dec 18, 2003 | 05:21 PM
99spanishGT
Guest
Posts: n/a
Default Re: what type of supplies for swap??? (spanishlude)
bump
Old Dec 18, 2003 | 07:20 PM
AndyD's Avatar
You should only need a head gasket and valve cover gasket, unless you took off the oil pan too. If you did..then you will need an oil pan gasket too.
It probably would be a good idea to change the water pump, timing belt, and head bolts too.
Based on the spun bearing...you might want to check the oil pump too.
That's all I know of.
Old Dec 18, 2003 | 07:58 PM
99spanishGT
Guest
Posts: n/a
Default Re: what type of supplies for swap??? (AndyD)
thanks
Old Dec 20, 2003 | 09:10 AM
99spanishGT
Guest
Posts: n/a
do you really think i need new head bolts
Old Dec 20, 2003 | 09:23 AM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spanishlude &raquo;</TD></TR><TR><TD CLASS="quote">do you really think i need new head bolts</TD></TR></TABLE>
No, you don't. It is really only a good idea if you plan on turboing, high horsepower cars.
If you are going N/A...you should be fine using your current bolts.
91crx-jace
Apr 22, 2012 04:36 PM
thi3v3z
Jun 19, 2009 06:52 AM
mk2mike
May 15, 2006 07:45 PM
bey
May 30, 2003 10:43 PM
hatchy
Apr 5, 2002 04:01 PM
