Going 5 lug (USDM) on my LS quick qeustion..(already searched)
Old Dec 18, 2003 | 11:27 AM
Nerologic's Avatar
Default Going 5 lug (USDM) on my LS quick qeustion..(already searched)
i have a complete 5 lug conversion from a USDM R, my question is is there any way i am going to be able to put this on my non-abs integ? i have doubts regarding this with the ABS thing and i dont know if i am going to be able to convert to 5 lug after all...anyone have input?
Old Dec 18, 2003 | 11:45 AM
IntEGNYC's Avatar
Default Re: Going 5 lug (Nerologic)
lots of guys yank the abs out of the cars. You shouldnt have any problems but i'd hand around for some other opinions. good luck on the conversion. hope you get the larger brakes too ... that's what i really covet from the 5 lug conversion!
Old Dec 18, 2003 | 12:56 PM
Nerologic's Avatar
im actually going to convert to ABS on my non ABS integ, i foung a local dismantler that chas a 00SI in the yard with all the ABS junk and he is going to work with me cuz im going to get so much, il do a write up and take TONS of picture and post a how-too in a few weeks once i get started....
Old Dec 18, 2003 | 04:13 PM
One Bad GeeSeeR's Avatar
Default Re: (Nerologic)
unless thats the canada version siR the us si didnt come with abs.
Carlo
Old Dec 18, 2003 | 06:58 PM
Sukebei Oni's Avatar
Default Re: (One Bad GeeSeeR)
you might not get good braking performance from your non abs master cylinder. you might not get enough pressure, but i'm not sure. you might want to check about getting a itr master cylinder.
Old Dec 18, 2003 | 11:53 PM
Nerologic's Avatar
wait so u guys are saying there is a way around the whole ABS setup??
Old Dec 19, 2003 | 10:54 AM
Nerologic's Avatar
anyone? no ABS theory?
Old Dec 19, 2003 | 12:45 PM
White Lightnin's Avatar
I have a GSR disk swap on my civic. The GSR had ABS and my civic doesn't. I just removed the sensors etc. No problems thus far.
Old Dec 19, 2003 | 11:58 PM
Nerologic's Avatar
hmm, this sounds liek ti might work but i want to make sure this will work with out starting on this project, or il have top wait to get all the ABS stuff..so anyone else?
Old Dec 20, 2003 | 07:13 AM
evil b's Avatar
just remove the abs sensors off the 5 lug suspension you have, and youll be set.
Old Dec 20, 2003 | 01:00 PM
Nerologic's Avatar
so is that it, just remove the sen's and im set..damn it might be easier then i though..now so do i also get an ABS M/C or will the stock LS one dop the trick? and maybe upgrade to a GSR non-ABS one or...?
Old Dec 21, 2003 | 07:21 PM
Nerologic's Avatar
Old Dec 21, 2003 | 07:35 PM
ophdehEEzY
Guest
Posts: n/a
Nerologic IS A SCAMMER
https://honda-tech.com/zerothread?id=711335
EricUSC
21
Apr 18, 2009 05:40 PM
TSAngry
Aug 21, 2006 09:26 AM
ILOVEGIRLS
Oct 18, 2003 11:57 AM
nijia555
May 8, 2003 08:40 PM
