pg 7 code list i need it bad and quick
Old Dec 18, 2003 | 08:16 AM
1990civicsiguye's Avatar
Default pg 7 code list i need it bad and quick
help im getting code 15 wont start after swapl.......
Old Dec 18, 2003 | 08:22 AM
YumVTEC's Avatar
Default Re: pg 7 code list i need it bad and quick (1990civicsiguye)
http://tech.hybridgarage.com/tech/codes.html
"Ignition Output Signal
missing or defective ignition output signal"
Old Dec 18, 2003 | 08:24 AM
thanks i found it too...... im going to check the wiring and then if need be replace ingitor.....thanks
Old Dec 18, 2003 | 11:57 AM
YumVTEC's Avatar
Default Re: (1990civicsiguye)
i haven't seen a bad ignitor throw a code before. i can pretty much guarantee you that if you have just performed a swap and are getting this code that you have a wiring problem, but you do what suits you best.
1_SC_GSR
Aug 14, 2006 10:24 PM
mastarolla
Dec 8, 2003 08:53 PM
