ep3 rear inner trim removal question
Old Dec 17, 2003 | 08:37 PM
al3e's Avatar
Default ep3 rear inner trim removal question
...its my girls car and im dont wanna mess it up anymore than what ive already done... i need to get access to the top of the shock... the three top bolts.. behind the trim.....how do i get that **** outta my way with out messing it up
Old Dec 17, 2003 | 09:14 PM
andyep3's Avatar
I just sort of pried mine off with a screwdriver,
but I ended up breaking a couple pieces of
plastic in the process. So I wouldn't do that.
It seems to fit back in place just fine, though.
Old Dec 17, 2003 | 09:15 PM
al3e's Avatar
Default Re: (andyep3)
yeah i almoast did that.... but she was kinda watching and almost bit my head off... yeah....
Old Dec 18, 2003 | 06:37 AM
fireant's Avatar
Default Re: (al3e)
Use a flathead screwdriver, and put some electrical tape on it.
Put it into the small tab at the top of the panel, and pry downward.
There is a metal clip right there that uses pressure to hold itself into a slot. Pry it just enough to get it loose, then using your fingers in there, continue to work your way down toward the rear of the vehicle, gently pulling it apart.
The good news: you will find that there are only two bolts on the rear suspension. You will need, without question, the following things to get to those bolts
1.) a 14mm DEEP socket...a regular wont reach over the threads, and there's not enough room for a regular wrench.
2.) an 8" socket extension, you'll need this to reach the bolt that is hidden deep in the corner.. (you'll know what I mean when you see it)
3.) A ratchet
Once you have those two bolts loosened, as long as the bottom is still connected, you can put a little wd40 on them and spin them off quickly with your fingers.
So once you get done, the torque values for those two bolts on top are 43 ft-lbs. The torque for the bolt that holds the bottom of the shock onto the arm is 45 ft-lbs. Thats 'very tight' if you dont have a torque wrench handy.
A pair of 'Mechanix' gloves from the Autozone will make this go easier on your hands... often the pressure the wrench puts on your hands gets too painful long before you have pulled or pushed as hard as you can. Those gloves give you added strength in a way.
Old Dec 18, 2003 | 07:31 AM
al3e's Avatar
Default Re: (hatch2k)
woa thats what i needed to know x 2 thanks a bunch man
Old Dec 18, 2003 | 09:35 AM
fireant's Avatar
Default Re: (al3e)
Heh, do you get the impression that I was just doing this last weekend? I was.
Old Dec 18, 2003 | 11:20 AM
k-series's Avatar
http://www.k-series.com/tech_d...STRUT
Steve
Old Dec 18, 2003 | 12:13 PM
al3e's Avatar
lol yeah i woulkd have asked if u did it last night ha
hmong337
26
Jun 25, 2010 02:30 AM
dukers
Jul 29, 2005 05:06 PM
Mike_C
Nov 22, 2003 05:23 PM
gsr-2nr
May 25, 2003 10:55 PM
RustyRex
May 10, 2003 06:09 PM
