mitsubishi turbo on lude
Old Dec 17, 2003 | 07:28 PM
HONDA-2NR's Avatar
Default mitsubishi turbo on lude
what kind of mitsubishi turbo would be good to slap on to a H23A1 (auto). I am going to do some kind of project with my lude. im putting my own cheaper turbo kit on it.
Also, I bought some unothodox racing pullies (alt, ps, crank) I have not installed them yet. Will they give me a good amount of power.
Old Dec 17, 2003 | 07:35 PM
KW2000's Avatar
Default Re: mitsubishi turbo on lude (HONDA-2NR)
ummm.......do some search on the pullies....and ummm i guess u can put any mitusbishi turbo on your lude but its not goin to be able to just slap on.....you gotta know your stuff when doin custom turbo kits mang...do your homework till you decided on this...maybe think about saving for a 5spd swap
Old Dec 17, 2003 | 08:36 PM
Shakes's Avatar
space cadet
Default Re: mitsubishi turbo on lude (KW93LUDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KW93LUDE &raquo;</TD></TR><TR><TD CLASS="quote">you gotta know your stuff when doin custom turbo kits mang...do your homework till you decided on this...maybe think about saving for a 5spd swap</TD></TR></TABLE>
everything he said.
if you cant afford to boost properly, you cant afford to boost. it is expensive and can easily turn into a black hole for your wallet.
do your research, A LOT of research.
Old Dec 17, 2003 | 09:46 PM
LudeyKrus's Avatar
Search, it's been covered before.
If you're gonna do this, you use the turbo and manifold from either a 1st or 2nd gen turbo DSM. The first gen's used a 14b, and the second gen's used a T25....the 14b is more desirable.....and I have a 14b DSM manifold for sale!
Old Dec 19, 2003 | 10:43 PM
95ONE's Avatar
Default Re: (jz)
Are you guys saying the manifold bolts right up to the head!?
Old Dec 20, 2003 | 01:22 AM
2+2=5's Avatar
Default Re: (nsxlr8)
dont even plan to have a turbo with a limited budget, sure you can build a junk yard setup but you gonna have alot of tuning done if you want the motor to last.
I am not hating on turbo, my pos is turbo'ed before.
you can use dsm manifold on some F series, I am not sure about on h23 tho'
a t3t04 would be the ideal size of snail, but besure to beef'ed up your tranny, coz the bands and servo gonna take a dump on you if you boosting anything more than 7 psi
dont expect the pulley would give you mad vtecH powa, it's a honda, no singel one bolt on mod would give you alot of power.
unlike the turbo supra, which get 100+ just for bolt ons
Modified by 2+2=5 at 10:33 AM 12/20/2003
Old Dec 20, 2003 | 01:31 AM
2+2=5's Avatar
Default Re: (2+2=5)
a little list if you looking for custom turbo
Must:
manifold
intercooler piping
intercooler
downpipe
BOV
Turbo
all the gaskets
Map sensor bypass(fish tank valves)
warlbro fuel pump
Fuel management unit
colder spark plug
boost gauge
wastegate(or internal wg)
oil line(supply/return)
silicone fastener w/ clamps
optional goodie
hondata/aem ems/apexi vafc
test pipe(with o2 sensor bypass or hondata)
free flow exhasut
alot of money
dyno tuning
a/f gauge(better than nothing)
exhaust gas temp guage
obd1 conversion
5speed tranny with beefier clutch
oil cooler
ATF cooler(for autotrans)
total boost by corky bell(a book by the king of turbo)
that's all i remember top of my head..ar..custom turbo should run you about 1500-1700, know how to weld would be VERY helpful.
H23 is good with boost, that's what i been told, I am an accord guy anyway.
Old Dec 20, 2003 | 08:27 AM
LudeyKrus's Avatar
The DSM mani will fit onto the H23 AND F22 heads, you just gotta redrill the head bolts(no sweat). The turbo WILL be smallish, but it'll do the job, and will give good gains for the money. This turbo will give very good low-end w/ no lag, but will die out a bit on the top end.
And yes, a budget turbo setup can be done reliably. I would get:
DSM Turbo and mani, DSM 450cc injectors w/ AFC hack, adj. FPR, DSM metal BOV, and big volvo/NPR/starion i/c......done right, it will give modest gains at a modest price.
Old Dec 20, 2003 | 11:22 AM
2+2=5's Avatar
Default Re: (LudeyKrus)
f22b1 and non-vtec got a totally different exhasut port design, right?
so which one fits?
Old Dec 20, 2003 | 12:04 PM
LudeyKrus's Avatar
The F22 that comes in the Prelude, and I think the Accord, uses the same port design as the H23, just maybe different headbolts. The Accord guys have been doing this budget boost setup for a long time, and the F22 can make about 200hp on this setup due to the motor's design.
Exvtec king
17
Jul 10, 2007 11:07 AM
PRODIGYRSX
Nov 16, 2006 07:57 AM
2 Loe 4 Fat Hoes
Jul 3, 2005 05:26 PM
andysila
Jan 29, 2005 12:37 PM
16vmini
Acura TL, RL & ZDX
26
Jun 10, 2004 01:56 PM
