Integra console?
Old Dec 17, 2003 | 12:30 PM
89hatchback's Avatar
Default Integra console?
How hard is it to install an integra console into a 89 hatchback std. and what year integra console do i need to get? thanks
Old Dec 17, 2003 | 12:37 PM
4crx4me's Avatar
Default Re: Integra console? (89hatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hatchback &raquo;</TD></TR><TR><TD CLASS="quote">How hard is it to install an integra console into a 89 hatchback std. and what year integra console do i need to get? thanks </TD></TR></TABLE>
Not sure about the 1G tegs but the 2G's don't have a console, to speak of really, so you're gonna need a console from a 3G teg '94-01.
HTH
Old Dec 17, 2003 | 12:46 PM
Targa250R's Avatar
be professional
Yep, '94-01.
Old Dec 17, 2003 | 12:47 PM
EL Vap133's Avatar
Not hard at all, it's pretty much a direct bolt on...
Here is a link with a "how-to" https://honda-tech.com/zerothread?id=335892
Old Dec 18, 2003 | 01:42 AM
payneth's Avatar
very easy, all you need to do is take lower console out of the ef, and put in the 94-01 teg console. if you have si seats tho its a lil more tight fit than the std etc... seats. but yes basicly direct bolt on besides the minor gap fron the lower console of the teg to the radio (upper console) on the ef. but looks great!
Old Dec 18, 2003 | 04:30 AM
Home Skillet's Avatar
I did the 1st gen teg because it was very cheap at the junk yard and it fits more stuff in the pockets.
Old Dec 18, 2003 | 06:27 AM
ThefirstPACT's Avatar
Default Re: Integra console? (Home Skillet)
Looks nice! My friend has the 94-01 console in his he love it!
Old Dec 18, 2003 | 06:34 AM
ITSTOCK's Avatar
Default Re: Integra console? (1CAMcan)
if u do a search for armrests youll find a **** load of threads, there was one recently and theres a company that makes aftermarket ones with cupholders for $80
Old Dec 18, 2003 | 07:20 AM
UNDER PRESSURE's Avatar
Default Re: Integra console? (ITSTOCK)
Can this be done on a four dour?
Old Dec 18, 2003 | 07:51 AM
EL Vap133's Avatar
Default Re: Integra console? (UNDER PRESSURE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNDER PRESSURE &raquo;</TD></TR><TR><TD CLASS="quote">Can this be done on a four dour?</TD></TR></TABLE>
Hmmm, haven't seen it done personally but I am sure there is a way...
Old Dec 18, 2003 | 08:11 AM
T-Mo's Avatar
yes on another forum I was on the guy tried it in his four door, but he had to turn the seat belt thing around so that it would clear. Check it out here: http://www.automotiveforums.co...27374
Old Dec 18, 2003 | 08:17 AM
EL Vap133's Avatar
Default Re: Integra console? (T-Mo)
Looks good!
Old Dec 18, 2003 | 09:25 AM
Default Re: Integra console? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Looks good!
Yeah bro thanx for the info.
Old Aug 22, 2004 | 09:12 PM
spoonslpr21's Avatar
i have the 1st generation teggy console that i want to install in my 4th generation but when i tryed to install it there was a gap between the civic radio console and the integra console on the side
Modified by spoonslpr21 at 8:28 AM 8/23/2004
Old Aug 23, 2004 | 02:35 AM
quik89's Avatar
i have one in my 4 door, teggy 94-01 style, fit's perfect and looks awesome, didn't have to change anything with my seatbelts..........let me know if you want pics!!
Old Aug 23, 2004 | 03:43 AM
Fleas_Ef's Avatar
they come out of 94+ integras and they are easy to fit, u take off the bottom part of ur console where the ciggy lighter is, and then u put the new one on, not a perfect fit to the console but makes a big difference i love em
Old Aug 23, 2004 | 06:01 AM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (quik89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik89 &raquo;</TD></TR><TR><TD CLASS="quote">i have one in my 4 door, didn't have to change anything with my seatbelts</TD></TR></TABLE>
is that with auto seatbelts or the manual ones? and pics please!!
Old Aug 23, 2004 | 10:22 AM
crx si 2004's Avatar
usdm audio option out of a civic and type r shift boot BOLTS UP PERFECT
http://www.we-todd-did-racing....DE%3D
Old Aug 23, 2004 | 10:25 AM
ecahatch's Avatar
Senor Miembro
nice pics
Old Aug 23, 2004 | 10:38 AM
sohc hatch's Avatar
Default Re: (ECAhatch)
Hey looks good guys - I personnaly have a full CRX dash swap - If I can get a pic I will try and post it so you guys can get a look. You have all probably seen it.
Home Skillet: I like how you mounted your afc there wether it be a vafc or safc or avcr lol. What did you ude to do it ? You wrapped your ac vents with color matching vinyl ? Major Props on the creativity there - first time I see that personally. Let me know if possible.
Crx SI 2004: What yr civic are you mentioning there ? 92-95 ? 96-98 ? Xcetera. Looks real clean - Good Job on the craftmanship.
Everyone looks good - keep it up pplz. Good Luck.
Good Day,
RH.
Old Aug 23, 2004 | 03:29 PM
Default Re: (egturbohatchback)
its an optional ef part. 88-91 civic audio console. same as jdm one, different from edm one also the "jdm" armrest was a usdm option in the civic aswell
Old Aug 23, 2004 | 09:24 PM
Sh4d's Avatar
Default Re: (crx si 2004)
Old Aug 23, 2004 | 09:42 PM
Jonathan_ED3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Mo &raquo;</TD></TR><TR><TD CLASS="quote">
The only problem I see with his idea is that when you flip the seatbelt assemblies, it puts the unbuckle switch directly beside the seat-back; it'd be nearly impossible to reach!!
Plus you'd have to slide your fingers UNDER the lap belt to get access to the unbuckle button; the lap belt would be higher and farther back on your stomach....it's not going to meet the body right if you get into a wreck!
Old Aug 23, 2004 | 11:32 PM
MestizoRacer310's Avatar
Default Re: (JC18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JC18 &raquo;</TD></TR><TR><TD CLASS="quote">
is that with auto seatbelts or the manual ones? and pics please!!</TD></TR></TABLE>
Guessing that he didn't have to change anything seat belt wise, I'm going to have to say manual. GOD I hate these auto seatbelts...
Old Aug 24, 2004 | 01:18 AM
quik89's Avatar
Default Re: (JC18)
that's with the manual seatbelts, i can't find the digi camera to take a couple pics at the moment, but this an alright pic of it,
i will throw a couple better ones on here possibly tuesday if i can find the camera......
