difference between JDM and USDM engines/what motor can I put into 90Si
Old Dec 17, 2003 | 09:37 AM
90SiB21A1's Avatar
Default difference between JDM and USDM engines/what motor can I put into 90Si
I was hoping someone could let me know what engine other than the B21 will fit into a 90 Si with little or no modification to bolt it up. Also is a JDM B20A a good motor to replace a blown B21A. I can get a good deal on a JDM engine. What is the difference between JDM and USDM engines. Is there any other motors I could use with the Si 5-speed? Thanks for any info.
Old Dec 17, 2003 | 10:13 AM
Boost Ambassador's Avatar
Default Re: difference between JDM and USDM engines/what motor can I put into 90Si (90SiB21A1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90SiB21A1 &raquo;</TD></TR><TR><TD CLASS="quote">I was hoping someone could let me know what engine other than the B21 will fit into a 90 Si with little or no modification to bolt it up. Also is a JDM B20A a good motor to replace a blown B21A. I can get a good deal on a JDM engine. What is the difference between JDM and USDM engines. Is there any other motors I could use with the Si 5-speed? Thanks for any info.</TD></TR></TABLE>
A lot of people on this board will greatly appreciate the capabilities of the B20A... plenty of torque and you can alawys get a VTEC head for top end later.
As far as JDM motors and USDM goes JDM is strictly from Japan usually with less miles than USDM. Best of luck
hondaistheboss
Honda Civic (2006 - 2015)
14
Feb 19, 2008 07:53 AM
ekVtecPower
13
Mar 15, 2006 07:22 PM
shatchi
Nov 17, 2004 01:34 PM
auburnBoy
May 27, 2004 06:38 PM
Irishweird00
16
Feb 7, 2003 09:01 PM
