USDM vs JDM difference??
Re: USDM vs JDM difference?? (e gee two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e gee two »</TD></TR><TR><TD CLASS="quote">jdm by a hair by the way</TD></TR></TABLE>
x2 ...
x2 ...
Some are more different than others, depending on which motor you're talking about. For example, the B18C (jdm) is 180hp whereas the B18C1 (usdm) is 170hp. Not true in all cases though.
there is no answer to which is better. lets talk about Dseries. i got a D16z6 1.6L sohc vtec makes 127 flywheel horsepower, i also got a JDM D15b 1.5L sohc vtec and it makes 130hp. basically the same out of a smaller motor, why???? no emmisions in JAPAN, therefore they can run higher compression from the factory, and have higher octane fuel. on the other hand you have cost. USDM is definately better in this case, so which is better a few HP or a few $k, you decide.
Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">there is no answer to which is better. lets talk about Dseries. i got a D16z6 1.6L sohc vtec makes 127 flywheel horsepower, i also got a JDM D15b 1.5L sohc vtec and it makes 130hp. basically the same out of a smaller motor, why???? no emmisions in JAPAN, therefore they can run higher compression from the factory, and have higher octane fuel. on the other hand you have cost. USDM is definately better in this case, so which is better a few HP or a few $k, you decide.</TD></TR></TABLE>
Also, for us CA residents, JDM is a PIA because of smog referee issues...
Jonathan_ED3
04-18-2002 08:44 PM
