oil pan ? D16Z6_D16A6
Old Dec 17, 2003 | 08:10 AM
fast-rex's Avatar
Default oil pan ? D16Z6_D16A6
hay guy's will the oil pan from the Z6 block fit the D16A6 block? THANX FOR ALL THE HELLP!
Old Dec 17, 2003 | 08:54 AM
oldskoolhatch's Avatar
Default Re: oil pan ? D16Z6_D16A6 (fast-rex)
I am almost positive it will work, ive used an oil pan from a Si on a dohc zc, so im pretty sure all d-series are the same, good luck.
Old Dec 17, 2003 | 09:15 AM
APEX CRX's Avatar
yup, exact same oil pan as the block is basically the same
Old Dec 17, 2003 | 09:23 AM
4drEF's Avatar
Keyboard Humorist
Default Re: oil pan ? D16Z6_D16A6 (oldskoolhatch)
FYI - A6 might fit on the Z6 (not sure), but the Y8 is on it's own and won't fit any other D blocks.
Old Dec 17, 2003 | 10:38 AM
fast-rex's Avatar
Default Re: oil pan ? D16Z6_D16A6 (4drEF)
THANX FOR ALL THE -INFO- GUY'S
Old Dec 17, 2003 | 12:34 PM
JCracer723's Avatar
ive heard about the a6 been compatible with the z6 .... BUT .. ive tried the a6 on the z6 and didn't work ... the oil pick up was hitting the pan ... but the z6 might fit the a6 ..
Old Dec 17, 2003 | 02:15 PM
UNDER PRESSURE's Avatar
Default Re: oil pan ? D16Z6_D16A6 (JCracer723)
The reason he's asking is because I have a Z6 engine that used to be turbo'd and he has a A6 engine, I told him he could have the oil pan off my Z6(it's tapped for the oil return) if his A6 oil pan would fit my '95 ex civic. So the main question is will one fit the other and vise-versa(A6->Z6 and Z6->A6)?
Old Dec 17, 2003 | 04:55 PM
Garrett's Avatar
Default Re: oil pan ? D16Z6_D16A6 (UNDER PRESSURE)
d16a6 pan is not the same as the DOHC zc, try to use a d16a6 pan on a ZC DOHC with the OEM ZC header you will cry
turbocivic1984
Jul 29, 2008 09:54 AM
civicb16eg
Jun 25, 2008 06:45 PM
THEDirtyDseriesWOOT
Dec 17, 2006 04:46 PM
The Destroyer
Apr 3, 2006 06:59 PM
The Destroyer
Feb 26, 2006 06:35 PM
