95 ls with 92 ls tranny into a 90 civic hatchback non si
im trying to find out about the wiring harness and if the swap is a basic drop in did many swaps but never did a swap
like this is there any mount problems i need info
to
to
You will need an EF B-Series motor mount kit like HASport, HCP, etc. You'll also need a custom shift linkage from the manufacturer that you buy the mount kit from or a modded 90-93 Integra linkage. If the car is DPFI, which it should be then you MUST reuse the stock DPFI engine harness and rewire it to MPFI. Then you will need to decide if you will stay OBD0 or go OBD1 which would then require some additional wiring.
boosted 95 coupe
12
Jan 12, 2007 03:25 PM
