How to on removing the oil pressure switch
Old Dec 16, 2003 | 06:27 PM
civic15.8's Avatar
Default How to on removing the oil pressure switch
How do you remove the oil pressure switch i have pulled on it and turned it but i cant get it off. i need to get it off so i can finish my turbo.
oh yea i have done a search.
type car is in the sig.
Old Dec 16, 2003 | 07:50 PM
civic15.8's Avatar
Default Re: How to on removing the oil pressure switch (civic15.8)
my bad i messed up it is not the oilpressure switch but it is the plastic cover on
Old Dec 16, 2003 | 08:12 PM
Erik_Pb_Foot's Avatar
New User
on the back of your block? it threads out like any bolt does..... be sure to use some teflon paste when you put your new fitting in.
Old Dec 16, 2003 | 09:16 PM
civic15.8's Avatar
Default Re: How to on removing the oil pressure switch (Erik_Pb_Foot)
no i mess up in my first post it is not the piece that threads in it is the piece that covers that piece and it is black and has wires going to it
Old Dec 17, 2003 | 03:46 AM
New User
pull and twist that off at the same time.... it's just a tight fit so twist as you pull and she should pop rigth off....
Old Dec 17, 2003 | 05:05 AM
SuzukaBlueAP2's Avatar
Thw wires should pull out first. You don't wanna chance breaking those.
<-------has had to repair the wires due to pulling too hard
Old Dec 17, 2003 | 05:09 AM
New User
Default Re: How to on removing the oil pressure switch (urbanracer98)
i always grab a hold of the wires with a pair of plyers as close to the block as possible to try to minimize tearing stuff up
-Erik <--- who's still ripped a couple
maxogsr
Dec 4, 2008 05:12 AM
aznevanchoi
Aug 24, 2007 11:58 PM
RACEPAK
Apr 30, 2005 12:55 PM
egg_baLLa
Jan 28, 2005 07:57 AM
