could this be because of the OBDII ecu?
Old Sep 21, 2001 | 10:23 AM
greenGSR12's Avatar
New User
Default could this be because of the OBDII ecu?
I have a 96 GSR. I just put a new exhaust on it and shortly after my check engine light came on. I then checked the computer and it came back with the ecu problem code for my VTEC pressure valve. My question is could this be because of the OBDII computer? my friend said that is why my check engine light came on. Any help is appreciated.
Old Sep 21, 2001 | 10:28 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: could this be because of the OBDII ecu? (greenGSR12)
Because you installed an exhaust? I highly doubt it.
Old Sep 26, 2001 | 06:28 PM
kulsvea's Avatar
New User
reset your computer for about 10 minutes (pull the neg cable off battery or pull fuse for ecu). It could also be you O2 sensor. If you gutted the cat or put high flow cat on that's your problem. Reset your ecu and see if that helps.
Car Tweaker
May 6, 2007 12:25 PM
k20EP3
22
Dec 8, 2006 12:09 PM
bo0sted
Sep 17, 2004 02:53 PM
CleanLIttleLude
Jun 13, 2003 12:09 PM
AzianAvenger
Aug 6, 2001 06:46 PM
