what products are good to stop vibrating?
Old Dec 16, 2003 | 12:45 PM
itsJDMyo's Avatar
Default what products are good to stop vibrating?
i recently got a system, and now, i can hear a whole lot of vibrating in the trunk and the rear. mostly from the rear, i think it's behind the seatbelt hook on the panel. and my rear licence plate is vibrating like a bi0tch. there is only 2 screw's holding it in from the top. the reason i don't have any for the bottom, because there is no holes for it, should i just drill my own holes? and what products are good to stop the vibrating noises??
Old Dec 16, 2003 | 01:05 PM
EVIL TYPE R's Avatar
Default Re: what products are good to stop vibrating? (b00st)
try dynamat
Old Dec 16, 2003 | 05:55 PM
brads94accord's Avatar
just find exactly where its vibrating and take it off and use double sided tape, foam, rubber, anything to put in between. don't waste your money on dynamat, it is for sound deadining. you need to just rig something up in there to stop it
Old Dec 16, 2003 | 11:06 PM
Peter Griffen
Guest
Posts: n/a
Default Re: (brads94accord)
A cheap alternative is peel and seal from Home Depot.
One of the stereo people's tricks to save money on dampening.
Stuff works and is cheap.
Old Dec 16, 2003 | 11:16 PM
GSRrR's Avatar
http://www.raamaudio.com/
rick makes a great product.
Old Dec 17, 2003 | 07:34 AM
made you look
Guest
Posts: n/a
for your license plate use zip ties, they absorb the shock
Old Dec 17, 2003 | 10:24 AM
..::91TEG-G2::..'s Avatar
Default Re: what products are good to stop vibrating? (EVIL TYPE R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL TYPE R &raquo;</TD></TR><TR><TD CLASS="quote">try dynamat</TD></TR></TABLE>
good if u dont mind ur car being a little heavier.. if ur trying to go for speed, and have a light audio system in ur car, dynamat isnt the answer!! but its up to you
Old Dec 17, 2003 | 06:09 PM
itsJDMyo's Avatar
Default Re: what products are good to stop vibrating? (..::91TEG-G2::..)
bump, i just found out what was rattling the most. it's the rear piece in the back. i have a 95' civic coupe...it's like a rear panel, where the 3rd brake light is. sorry if this is kind of vague...but i don't really know how to explain it. is there a way i can tighten it or something?
Old Dec 17, 2003 | 06:41 PM
itsJDMyo's Avatar
^^bump?!?^^
Old Dec 17, 2003 | 08:18 PM
thats what rattles in my accord. that and the B pillars. my third brake light rattled pretty bad but what i did is took it off and cut out little pieces of rubber and put them between the body and the screws. and cut a little piece of polyfill foam and put it underneath. it worked really good and it doesn't rattle anymore. next week i'm gonna take off the rear deck and B pillars and fix the rattles with some foam and those little pad things that go on the bottom of your furniture to keep from scratching the floor.
civicvtec44
Paint and Body
Apr 29, 2009 07:04 PM
mooseheads36
Honda Civic (2006 - 2015)
Feb 14, 2007 06:36 PM
Civic97s
Audio / Security / Video
May 28, 2005 01:08 PM
RAF LTD.
25
Oct 19, 2002 10:45 PM
Feb 22, 2002 12:50 PM
