DynaMat
Old Oct 3, 2002 | 10:34 AM
RAF LTD.'s Avatar
Default DynaMat
Anyone know a cheap way to make the rattle go away, DynaMat isnt cheap (15bucks a sq foot) geez we probably need to coat most of the GSR trunk. Anything else we can use.
Old Oct 3, 2002 | 11:01 AM
loki2323's Avatar
Default Re: DynaMat (RAF LTD.)
do a search on ebay...they have stuff that is pretty much the same thing...but a whole lot cheaper
Old Oct 3, 2002 | 01:53 PM
o_Rage_o's Avatar
Default Re: DynaMat (loki2323)
brown bread http://www.b-quiet.com
or rammmat on ebay.
Best quality stuff for real cheap.
-Rage
Old Oct 3, 2002 | 02:04 PM
RAF LTD.'s Avatar
Default Re: DynaMat (o_Rage_o)
nice. Now for when you install it whats best, like what parts of the car should we put it on so that the rattle goes away?
Old Oct 3, 2002 | 06:42 PM
loki2323's Avatar
I havent done my car yet...but I am planning on doing my entire trunk with it...the rear deck is going to get a layer....also going to take my doors apart and put a layer or two on the doors....from what I have heard...it makes some what of a difference in making things less noisy.
Old Oct 3, 2002 | 08:21 PM
JDubya's Avatar
I used brown bread, its great stuff. I took off my door panels and put some of the mat on the inside of the ousdide sheet metal, like the part thats painted (if that makes sense...) then i put more mat over all the holes on the inside part of the door to make it air tight. then i put a lot of mat on my whole hatch area. try to make it air tight if you have a system and dont want rattling. after you put it all down, tap on certain parts and if they seem real resonant then add more layers till it sounds like more of a thud when u hit it.and make sure you get all the air bubbles out.
Old Oct 4, 2002 | 11:00 PM
incubus's Avatar
u can use carpet padding for pretty cheap too, most of the korean manufacturers use it in their cars already behind the panelling. cheap and effective.
I used to work at Best buy and there is ungodly markup on dynamat, with my discount it was like 70% off. i had my accord coated in dynamat. It didn't even work completely and i used almost all dynamat extreme.
Old Oct 5, 2002 | 06:21 AM
jdmotorsports's Avatar
Default Re: DynaMat (incubus)
i use a combination of 3m rubberized undercoat and down great stuff foam. no rattles in my teg, and i have that stupid metal panel below the tail light. not you cant hear a thing but music.
Old Oct 5, 2002 | 12:32 PM
o_Rage_o's Avatar
Default Re: DynaMat (jdmotorsports)
get those panels in the rear speaker location, you gotta reach behind the actual mount (this is all with the plastic sides off) it will allow you to get to the sheet metal of the actual body, Brown bread that, and the doors for the biggest dampening difference.
As for rattles, license plate (throw some 3m double sided window insulating tape behind it) is usually a huge one.
-Rage
Old Oct 5, 2002 | 06:03 PM
RAF LTD.'s Avatar
so you dont think the dynamat was any better than this carpeting? and if so where do you buy the carpet stuff. Anyone else have experiance with this?
Old Oct 5, 2002 | 07:30 PM
95 GaNgStA AcCoRd's Avatar
Where did u put the great stuff foam? I just put it on my trunk lid today and i didn't notice n e difference.
Old Oct 6, 2002 | 12:47 AM
Dremgragen's Avatar
RAAMmat is almost exactly the same as Dynamat. Quality stuff without the brand name. You want RAAMmat 60, it's identical to Dynamat Xtreme.
Other people have tried Peal N Seal from their local Lowes or Home Depot and had great results. It's pretty cheap too.
I have 248 square feet of RAAMmat 60 in my '95 Civic. I don't have any of my interior put back in except the dash, and my car is already a world of difference quiter than it was before I started. I'm extremely happy.
Old Oct 6, 2002 | 04:12 PM
n0 iNTegRiTY's Avatar
Default Re: DynaMat (Dremgragen)
how much did the 248 feet of this RAAMmat stuff cost?
Old Oct 6, 2002 | 07:54 PM
MachAF's Avatar
Default Re: DynaMat (RAF LTD. 2)
check out http://www.edesignaudio.com
get some Edead.. works GREAT....owner is a GREAT GUY!!
Old Oct 6, 2002 | 08:56 PM
Default Re: DynaMat (95 GaNgStA AcCoRd)
gotta make sure it expands all the way. takes a day or so to cure
Old Oct 6, 2002 | 09:38 PM
incubus's Avatar
both dynamat and carpet underpadding are useful, not every part of the car needs tha same type of dampener, underpadding can be purchased at any home depot or carpet store. you will also need to buy adhesive which they will probably seel right next to it, if it does not have an adhesive back.
Old Oct 7, 2002 | 05:27 AM
merlyn's Avatar
i would highly suggest raamat from http://www.raamaudio.com or ebay. The guy is an awesome guy to deal with...he REALLY knows his stuff. Excellent customer service, and if you live in San Diego/ oceanside, you can pick it up, like I did.
Old Oct 7, 2002 | 07:08 AM
o_Rage_o's Avatar
You would not...thats because there are some things you guys don't realize.
STOPPING RATTLES
You need to add mass to a panel to alter its resonant characteristics so that it won't rattle at the frequencies you play at now.
To add panel mass you need dynamat, brownbread, rammmat etc.. foam is obviously too light and therefore no difference.
STOPPING NOISE
To stop noise you need something that will absorb the sound, ie. carpet padding, foam spray, liner etc. This stuff will hinder the sound from actually reaching your ears.
Coles: Use a combination of both mass adding and absorbing materials to get the most out of your vehicle...
-Rage
Old Oct 8, 2002 | 12:50 PM
yeah..what rage said. plus with the foam, you need to make sure the area your filling is super tight with foam. you can use duct tape to seal it off then fill it. if the metel cant move then it cant rattle.
Old Oct 9, 2002 | 10:24 AM
EndlEEsss's Avatar
BE CAREFUUUULLLLL when your working with spray foam.
that stuff gets all over the place and its really sticky.
so test some out on a shoe box, and make sure u get the hang of it.
dont get it on your vinyl or cloth or leather, it might not come off.
good luck, have fun
Old Oct 9, 2002 | 01:46 PM
The_In_Kid's Avatar
lower the volume
Old Oct 19, 2002 | 01:52 AM
MestizoRacer310's Avatar
Ok, my situation's not ICE related, but more along the lines of exhaust noise. It's pretty "quiet" from outside the car...but inside it's sometimes unbearable and now that my girl's pregnant I heard that it can't be exposed to loud noise. What can I do to keep the exhaust for performance but quiet it down for passengers??
I'm running a 2.5" tubing cat back w/ a 22" long cherry bomb [as resonator] and a dual DTM muffler. Even w/ the cherry bomb "resonator" it's still too f'kin loud. Any thoughts??
Old Oct 19, 2002 | 01:59 PM
EndlEEsss's Avatar
Default Re: DynaMat (TeamDynasty91AccordEX)
hey just give me your exhaust
Old Oct 19, 2002 | 02:40 PM
rcurley55's Avatar
New User
Default Re: DynaMat (TweakMeUp)
If you use expanding foam, you run the risk of bending your trunk lid....be very careful when filling a trunk lid with this stuff. you should use the latex based variety so that it won't squeak when cured. Also don't use the superexpanding style....use the low expanding type.
I would actually drill holes in the stiffening braces...that way, if you add too much, it will spill out the holes rather then warp your trunk lid.
Old Oct 19, 2002 | 06:27 PM
mrvinyl33's Avatar
New User
Has anyone used this before to stop speaker rattles in stock locations?
Dynamat 10115 Original Speaker Kit
http://www.crutchfield.com/cgi-bin/S...890&I=15410115++
