90 crx - and i'm sitting on a gsr swap-question?
Guest
Posts: n/a
I have a carbon fiber hood with the middle lifted so it can clear the gsr motor - I have a d16 in it now. OBD1 with the vtec wired up. I know I need motor mounts, how should I deal with the shiftlinkage, axels and what ever else I left out?
Any help would be great.
Ok so you need shift-linkage-HA-sport will have that
I am taking that you know to get such things as new plugs, wires, cap, rotor, oil filter, oil, flush the radiator, brake fluid, pads maybe. When I did my swap I was not thinking about stopping, I put a B16 into a CRX and if I kept the stock brakes, I do not know if they would have stopped the car at WOT.
So I would get bigger brakes. 90-93 integra brakes bolt on.
extra money for stuff that you did not know about, I had to replace my CV boot and the radiator and starter 2 weeks after.
If I think of anything else I will post it.
dont worry about getting bigger brakes..my car stops perfectly fine with stock size. but yeah basically everything else they mentioned. good luck
[<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Home Skillet »</TD></TR><TR><TD CLASS="quote">A clutch would be wise to do while the motor is out of the car.</TD></TR></TABLE>
Good advice... and it goes without question a new clutch disc should be installed any time the motor is out.
But I think the original posters’ (Range) question was more geared to actual SWAP pieces needed to complete a swap instead of normal maintenance type items. Replacing the clutch /surfacing the flywheel, new pressure plate, release bearing , pilot bearing… AND input shaft seal should be done no question. At the very least if it’s a low mileage drivetrain trans and engine should be split, and everything inspected, clutch contact surfaces de-glazed and metal to metal contact surfaces re-lubed.
A thing to add to the list: ALL coolant hoses. Most remember the upper and lower radiator hoses but forget about the “other” ones on the intake manifold and such. Much easier on most cars /motors to get at them while the engine is out.
While the engine it out it’s a good time to clean the engine compartment… and maybe take a look at wiring harness looms to make sure none are worn, or have been cut. Good time to clean Multi-Plugs connections with electrical contact spray, then put on a coating of die-electric grease on all contact surfaces.
rob0589
53
Apr 9, 2006 04:58 AM
