What head gasket to get...
Old Dec 16, 2003 | 10:27 AM
AgentJam's Avatar
Default What head gasket to get...
My planned SOHC build will consist of the following, D16Y8, PM7 pistons with a final copression of ~12:1 depending on the head gasket i choose. What i want is just around 12.1:1. To do this i will need a head gasket that is between .059" - .065" with the mill i have on my head (.01").
I have been looking at the SCE Copper head gaskets at summit which they carry one that falls in my range however i have heard that copper gaskets don't seal as well. Is this true? The gasket is only $78. Either way i need to get a gasket within this range, what are my choices and what kinds of gaskets are better than others???
Hmm...would a D15B7 - D16A6 head gasket fit on my Y8??? That would give me 12.2:1
TIA,
Vince
Old Dec 16, 2003 | 03:13 PM
gassinit's Avatar
Default Re: What head gasket to get... (AgentJam)
Is that gasket #91366? SCE makes both the pro copper and TITAN self sealing copper gaskets. The TITAN incorporates bonded self sealing water passage gaskets and the strength of the copper combustion gasket. Email me for a price, I'll beat Summit's. You tried Mr. Gasket? I give um a call tomorrow and see what they have.
Old Dec 16, 2003 | 03:18 PM
MrTodd's Avatar
Default Re: What head gasket to get... (gassinit)
The A6/B7 headgasket will work on the Y8, but it's kinda weak. It would have the highest chance of blowing.
Where did you find the TITAN SCE headgasket?
My setup is going to be very similar to AgentJam's, so I was hoping to get some info from you as well!
Old Dec 17, 2003 | 05:46 AM
AgentJam's Avatar
Default Re: What head gasket to get... (MrTodd)
Yeah I'll need the T91366 (Titan). This will give me a 12.1:1 comp ratio with my head mill and that's perfect
Old Dec 17, 2003 | 06:30 AM
AgentJam's Avatar
Hey MrTodd check these links out though...
https://honda-tech.com/zerothread?id=91501
https://honda-tech.com/zerothread?id=459126
Old Dec 17, 2003 | 05:47 PM
MrTodd's Avatar
Thanks for the heads up AgentJam. I'm definitely going after the Titan headgasket instead!
Old Dec 17, 2003 | 05:59 PM
AgentJam's Avatar
What's so different about the Titan? than the Pro...
Old Dec 17, 2003 | 06:24 PM
MrTodd's Avatar
Take a look, straight from their website...
http://www.scegaskets.com/products/titan.html
It looks pretty good to me I guess, but I haven't heard anything about it. I'm gonna send them an e-mail and see what they say. I Haven't found a place to buy them yet...
Old Dec 18, 2003 | 08:22 AM
gassinit's Avatar
I can get you the Titan T91366 but it may take me a week or two till I can send it out because it is a special order. ~115+/- a few $ plus shipping.
Old Dec 18, 2003 | 08:34 AM
AgentJam's Avatar
yeah let me make sure it's what i need because i don't want to have to o ring my block or something crazy. Thanks for helping me out though
drewlee
Aug 9, 2004 12:00 PM
S13 slide
Jan 4, 2002 06:20 PM
