91 CRX Axle swap
Old Dec 15, 2003 | 11:04 PM
kron0ne's Avatar
Default 91 CRX Axle swap
Does anyone know which axle would fit a obd1 ls tranny in a 91 CRX SI on the driver side?
Thanks
G. Spear
Old Dec 15, 2003 | 11:45 PM
POSef's Avatar
Default Re: 91 CRX Axle swap (lsi crx)
i would say a b16 axle, or usdm 94+ teg axle but no for sure....
Old Dec 16, 2003 | 12:31 AM
91hondacrx's Avatar
Default Re: 91 CRX Axle swap (95lsintegra)
I hate telling this to people cause i wish i knew the answer. But i know if you search you will find a definite axle for your car.
Matt
Old Dec 16, 2003 | 04:34 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know which axle would fit a obd1 ls tranny in a 91 CRX SI on the driver side?</TD></TR></TABLE>
As long as you are using a 90-93 Integra intermediate shaft then you will use 90-93 Integra axles. Since when did it matter what OBD tranny's are?
Old Dec 16, 2003 | 07:23 AM
BdoubleU's Avatar
Villan is correct about the intermediate shaft... 90-93 Integ. all share the same axels... so do the b16's. They also have the same spline count on the outer shaft so they fit the crx/ civic knuckle.
And Villan is also correct about the Obd issue also... The transmission does not have emission controls therefore there is no OBD label when refering to the transmission type sorry for being a smart ***!
Old Dec 16, 2003 | 09:30 AM
Alan Wil's Avatar
Default Re: 91 CRX Axle swap (BdoubleU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BdoubleU &raquo;</TD></TR><TR><TD CLASS="quote">Villan is correct about the intermediate shaft... 90-93 Integ. all share the same axels... so do the b16's. They also have the same spline count on the outer shaft so they fit the crx/ civic knuckle.
And Villan is also correct about the Obd issue also... The transmission does not have emission controls therefore there is no OBD label when refering to the transmission type sorry for being a smart ***!</TD></TR></TABLE>
Would you happen to know if the axles off a 91 Integra LS Auto-Trans car are the same as manual trans axles?
Got some for an engine swap.(B16/B18, or H22 into a 90 Civic DX. wondering if they can be used... Or what I should try to hunt up)
If I was Honda I'd be using the same axle for Auto /manual trans to cut down on cost.
Old Dec 16, 2003 | 09:33 AM
Adam F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsi crx &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know which axle would fit a obd1 ls tranny in a 91 CRX SI on the driver side?
Thanks
G. Spear </TD></TR></TABLE>
what mount kit?
Old Dec 16, 2003 | 10:29 PM
kron0ne's Avatar
Default Re: 91 CRX Axle swap (Adam F)
thanks for all the help...i know..its a YS1...bump for great honda tech members
thanks again for all the help
G. Spear
North Atlantic Motorsports
border919
Jan 23, 2009 09:07 PM
IwantaGlock18
Jan 6, 2007 01:27 PM
superbeastcrx
12
Nov 22, 2004 03:37 PM
Modified Motors
Sep 14, 2004 06:16 AM
