CL injectors vs. Prelude H22 injectors?
I'm swapping a H22 into my CL and i'm gonna use my harness, but the prelude injectors dont plug up to my harness, can I use my injectors on the H22, what will happen if I do? Whats the difference between saturated and peek and hold injectors, is there a better of the two? fill me in!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22CL »</TD></TR><TR><TD CLASS="quote">motor is 94 and my car is 99</TD></TR></TABLE>
94 H22A motor = peak & hold injectors = 330cc injectors on that particular model H22A motor. If you wanted to, you can use OBD-2 H22A injectors (270cc) as they are saturated injectors and do not require a FI resistor box and will plug into your harness w/out having to splice the plugs out. As for the CL injectors, dunno what spec they are but most likely around the 270cc, and not lower like B-series 240cc injectors.
